How Do I Adjust The Gas Flow To The Pilot Light On My Furnace? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-17-2009, 09:46 PM   #1
How do I adjust the gas flow to the pilot light on my furnace?
We had a service tech replace the pilot light housing on our Bryant furnace. The pilot light went from a small fingertip flame that barely touched the thermocouple to a blow torch the 1.5" x 1.5" square.
The tech said the flame didn't need adjusting, but it seems like an awful waste of gas. He'd also mentioned that there was a screw underneath another screw that would adjust the flame. I don't recall which screw he was referring to.
Is this a 'diy' project, or do I have to pay to have this guy come back?
4nxchg is offline   Reply With Quote
Old 10-18-2009, 12:17 AM   #2
There is probably a phillips head screw on top of the main valve and its probably the only one thats not in a corner. If you remove it there will be a very small adjuster screw some distance down the hole underneath it. You will need a jewelers screwdriver or other small straight blade screwdriver. Likely won't be able to see it but will just have to insert the screwdriver blade and feel for when it catches the slot. Clockwise to lower the flame IIRC. To be on the safe side, remove the top screw slowly and make sure you don't have any gas escaping. If so it's not the right screw
Mike in Arkansas is offline   Reply With Quote
Old 10-20-2009, 01:58 PM   #3
WaldenL's Avatar
Rewards Points: 268
I don't have a gas furnace, but I do have a gas hot water heater. A 1.5" flame is not a pilot light! I'd call the company that did the service back and have them send someone else. If it's under contract why mess w/it yourself.
WaldenL is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
10 year old Carrier mid furnace with standing pilot BryanGregoire HVAC 3 10-01-2009 07:16 PM
no pilot light adrenalic HVAC 12 12-19-2008 01:57 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
