Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-17-2010, 12:47 PM   #1
How to disassemble aluminum clad wood window sash?
Hi DIY gurus,
I have a large aluminum clad wood window sash (40w x 53h) in which the IGU has fogged and I am considering replacing the IGU rather than the entire sash. It is from a Marvin bay window unit, which seems to be a good quality unit, in that it is about 23 years old and the wood and aluminum seem to be in excellent shape. I have a good price on a new IGU from a manufacturer, but they won't install it in my wood frame. A local glass shop quoted double the price for the IGU plus TBD install costs. So I am wondering if I can remove and replace the IGU myself.
It looks like the aluminum cladding is fairly sturdy stuff but I can't say for sure if it is extruded or rolled. The 4 aluminum pieces appear to interlock at the corners, and hold down 4 corresponding vinyl pieces that are sandwiched between the aluminum and the glass.
So, how does one disassemble this to get at the IGU?
Note: I have already read the entire window defog thread, and may go that route, but let's try not to get sidetracked on that topic here.
JohnBinSC is offline   Reply With Quote
Old 04-17-2010, 05:28 PM   #2
Tom Struble's Avatar
remove the vinyl glazing bead with a putty knife
Tom Struble is offline   Reply With Quote
Old 04-17-2010, 05:50 PM   #3
Can you be a bit more specific? Is the "vinyl glazing bead" the 4 plastic pieces that are between the glass and the cladding at the edge of the glass (on the outside face)? If so, I have slipped a putty knife between this plastic and the glass, but it isn't obvious to me how to release anything this way.
If the "vinyl glazing bead" is something else, can you please be more descriptive? Thanks.
Old 04-17-2010, 06:03 PM   #4
just search removing marvin glazing bead...having a hard time posting a link
The Following User Says Thank You to Tom Struble For This Useful Post:
JohnBinSC (04-18-2010)
Old 04-18-2010, 12:37 AM   #5
OK, I found the pdfs of the reglazing instructions on the Marvin site. I'm pretty sure the one I need is titled "Reglazing Clad InSash Instructions" dated 4/22/2003. My unit does not have the aluminum glazing cap, so I guess I can just pry up the vinyl glazing strip. Nifty. I guess I will hunt around to see if there is a special pry bar to do this with less risk of breaking the glass. But it looks like it could not be easier.
Any opinions on whether I should buy the replacement IGU from Marvin or elsewhere? I guess I should ask what kind of warranty (if any) would be on the IGU if I install it.
Thanks a million!
Old 01-17-2011, 06:09 AM   #6
Simply put windows...are what you put in the holes in your house. Think about that. Holes in your house. It seems to me that if you are going to have holes in your house, you want a very good quality window to prevent the those holes from letting the conditioned air out and the cold air in and rain from destroying the interior of your house.
timberwindow is offline   Reply With Quote
Old 01-17-2011, 06:59 AM   #7
Super Moderator
Marvin is one of the best windows available--Duh
Tags
window igu aluminum clad
Insulating Aluminum Window Frames waynerlee Windows and Doors 25 04-26-2012 12:13 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
Sash Window renovation DED Carpentry 1 05-25-2005 02:32 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
