How To Cut, Trim Plastic Laminate Veneer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 02:09 PM   #1
how to cut, trim plastic laminate veneer
is there a method of trimming plastic laminate veneer if you do not have a router.we plan on covering existing laminate with a new veneer piece.what is the best way to cut the new veneer for the sink and faucet.thanks very much
alanq is offline   Reply With Quote
Old 09-19-2009, 05:41 PM   #2
Civil Engineer
Rewards Points: 4,778
I always use a router with a laminate trimming bit, however if you do not wish to buy a router, there are special purpose laminate trimmers (really just a lightweight router with a laminate bit) that you may be able to rent from a rental place, maybe even from a big box store. There are laminate bits that claim to be usable on a drill, however I am dubious, since the speed is much lower than on a router. I think a Dremel tool may have a special bit.
You may be able to trim with a diamond file, I have never tried it, but if you are really looking to save money on tools that may be worth a try.
Old 09-19-2009, 09:17 PM   #3
Registered User
Rewards Points: 5,516
Cuts with big tin snips, with router for holes.
Be safe, Gary
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
laminating counter tops ponch37300 Remodeling 3 05-13-2009 10:13 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
