Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-23-2012, 04:20 PM   #1
Question
How to cut plastic gutters
I am having a hard time cutting/sizing my plastic gutters. I swapped out the 10 inch blade on my miter saw and no matter what it is just chewing this stuff to shreds. I have cut PVC pipe with no problem but this stuff is far thinner. What can I do here?
tripower is offline   Reply With Quote
Old 09-23-2012, 04:21 PM   #2
Question
I am having a hard time cutting/sizing my plastic.vinyl gutters. I swapped out the 10 inch blade on my miter saw and no matter what it is just chewing this stuff to shreds. I have cut PVC pipe with no problem but this stuff is far thinner. What can I do here?
Old 09-23-2012, 04:26 PM   #3
Wire Chewer
Red Squirrel's Avatar
Hacksaw is probably your best bet. A mitre box or other device to keep it straight is probably a good idea too.
Old 09-23-2012, 04:28 PM   #4
#1 I would strongly suggest you not even use them. Take them back and pick up some Aluminum gutters instead.
I can list a number of reasons not to use them if you interested.
If your going to insist on using the plastic ones try installing a plywood blade and installing it backwards on the saw.
That's how vinyl siding is cut.
Old 09-23-2012, 04:38 PM   #5
the Musigician
DangerMouse's Avatar
I would think tin snips would do well?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 09-23-2012, 04:58 PM   #6
the Musigician
My suggestion would be tin snips. That's what I used on my vinyl siding and they worked fine siding my whole home.
DM
Old 09-23-2012, 05:29 PM   #7
Moderator
kwikfishron's Avatar
Put the blade in backwards and it will cut fine, same thing with vinyl siding.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 09-23-2012, 06:00 PM   #8
Average Joe/ex-Navy IC3
gregzoll's Avatar
Flip the blade, so the teeth are going in the opposite direction. Also using a finer tooth blade helps.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 09-23-2012, 06:08 PM   #9
Left and right snips ( aviation snips ) will work if you don't mind sacrificing an inch of material each cut.
Fairview is offline   Reply With Quote
Old 09-23-2012, 07:17 PM   #10
the Musigician
How would snips lose material? Measure, cut, done deal.
DM
Old 09-23-2012, 07:27 PM   #11
Moderator
-NEW MEMBERS-
Old 09-23-2012, 07:39 PM   #12
jschaben
I don't think much of running blades backwards, especially carbide tipped ones. Not to likely with thin plastic I suppose but the forces would be such to try to knock the tips off. Not as likely with a HSS blade. I still like aviation snips for the job.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
DangerMouse (09-23-2012)
Old 09-23-2012, 08:09 PM   #13
Davejss's Avatar
Hack saw. Better yet throw them away and buy seemless aluminum. Plastic gutters suck.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
joecaption (09-23-2012)
Old 09-23-2012, 08:19 PM   #14
Moderator
That's just fine and dandy but that's how you cut the stuff. I'ts more like a clean burn through the material than cutting.
+ 3 or 4 on plastic gutters are a bad choice to begin with.
-NEW MEMBERS-
Old 09-23-2012, 08:25 PM   #15
A steel plywood wood blade running backwards will do it.
There still going to be to narrow, going to have to have ugly brackets to hold them up, leaking couplings and end caps, will break if someone leans a ladder againt them.
But it will cut it.
And hold the gutter up side down when cutting.
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 06:56 AM
new drip edge over existing gutters scheiman Roofing 1 06-05-2010 08:44 PM
leaf free gutters icicles and ice dams bluemetro Roofing 16 02-23-2010 10:14 AM
cutting shingles to install gutters Chicago Bill General Discussion 2 02-27-2009 06:42 AM
Plastic instead of metal... hvaclover Electrical 11 11-13-2008 10:07 AM
