How To Cut A Hole In Tight Space - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-13-2011, 05:55 PM   #1
how to cut a hole in tight space
Hi
Im new to DIY but find this an awesome forum.
Anyway can anyone please tell if its possible to make this hole around this water valve bigger?
Its in such a tight space all I can think of is filing the wood...
I dont want the cabinet to fall one day and break the pipe!
THANK YOU!
how to cut a hole in tight space-5717199420_443d4b1dd3.jpg   how to cut a hole in tight space-5716634841_1b19095118.jpg
boogerz is offline   Reply With Quote
Old 05-13-2011, 06:18 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if you can get a file, or more properly, a rasp in there, you could do that. I would use either a die grinder bit or an abrasive roll in a dremel.
If you cant get anything in the opening, you can take a drill bit and drill a series of holes in an arc and then cut in between them with a razor knife and then use the rasp or other abrasive rotary tool as I first suggested to clean of the opening.
depending what that is, you might be able to just use a razor knife. A lot of cabinet backs are nothing more that luan and can be cut through with successive cuts with a razor knife
Old 05-13-2011, 06:27 PM   #3
Thank you soo much for the quick reply
Old 05-13-2011, 06:35 PM   #4
Handyman
Rewards Points: 512
Look at those burn marks! Yikes
canadaclub is offline   Reply With Quote
Old 05-13-2011, 06:36 PM   #5
Rewards Points: 558
Well my suggestion would be as follows:
1) Drill ½’’ holes tight together all around the existing hole and remove the debris.
2) Use a multi tool and cut your way around to make your hole larger.
3) Use a hammer and wood chisel to cut around existing hole
4) Disconnect fitting and remove cabinet if possible and drill with hole saw to desired diameter
Now I’m sure someone else will chime in and give you some more idea’s
epson is offline   Reply With Quote
Old 05-13-2011, 07:34 PM   #6
Learning by Doing
Leah Frances's Avatar
Ron Swanson would recommend using a Fein Multimatic.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-13-2011, 08:07 PM   #7
Handyman
Rewards Points: 512
Now , now Leah
I never understood the purpose of enlarging the hole in the first place.
Old 05-13-2011, 08:09 PM   #8
Rewards Points: 558
Originally Posted by canadaclub View Post
Now , now Leah
Didn’t you know? It’s a three stooge’s classic move…
Old 05-13-2011, 08:12 PM   #9
Handyman
Rewards Points: 512
nyuk nyuk nyuk
The Following User Says Thank You to canadaclub For This Useful Post:
Leah Frances (05-13-2011)
Old 05-13-2011, 09:13 PM   #10
thanks for the help again naps and epson!- im a newb so i duuno why those burn marks are there. can anyone tell me? btw pliers and a knife did the trick!
Old 05-13-2011, 09:22 PM   #11
Rewards Points: 558
The burn marks are there because the plumber soldered the fitting to the pipe and came to close to the cabinet with his torch.
Old 05-13-2011, 09:36 PM   #12
Handyman
Rewards Points: 512
He certainly did. Like the old proverb states. "Owa-tana-siam"
Old 05-13-2011, 09:38 PM   #13
Rewards Points: 282
rotozip
fein
either one would do fine, but that [birch?] plywood might not do well with the fien, probably too flimsy.
jcrack_corn is offline   Reply With Quote
Old 05-13-2011, 10:42 PM   #14
Old School
Willie T's Avatar
I'm sorry, but we try very hard to get those holes as small as possible when installing cabinets. Who in the world ever told you that a base cabinet could fall? That cabinet is not going to fall at all.
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
Leah Frances (05-13-2011), Tizzer (05-14-2011)
Old 05-13-2011, 10:54 PM   #15
Rewards Points: 558
something like this?
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
how to pick the right toilet for a tight space? ilyaz Kitchen & Bath Remodeling 1 05-27-2010 03:59 PM
End drain for center drain hole bbhicks Remodeling 0 04-19-2010 07:45 PM
Tight drilling angle fw2007 Electrical 8 05-31-2008 10:33 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 09:08 AM
