-   -   how to cut a hole in tight space (http://www.diychatroom.com/f2/how-cut-hole-tight-space-104389/)
boogerz 05-13-2011 04:55 PM
2 Attachment(s)
Hi
Im new to DIY but find this an awesome forum.
Anyway can anyone please tell if its possible to make this hole around this water valve bigger?
Its in such a tight space all I can think of is filing the wood...
I dont want the cabinet to fall one day and break the pipe!
THANK YOU!
nap 05-13-2011 05:18 PM
if you can get a file, or more properly, a rasp in there, you could do that. I would use either a die grinder bit or an abrasive roll in a dremel.
If you cant get anything in the opening, you can take a drill bit and drill a series of holes in an arc and then cut in between them with a razor knife and then use the rasp or other abrasive rotary tool as I first suggested to clean of the opening.
depending what that is, you might be able to just use a razor knife. A lot of cabinet backs are nothing more that luan and can be cut through with successive cuts with a razor knife
boogerz 05-13-2011 05:27 PM
Thank you soo much for the quick reply
canadaclub 05-13-2011 05:35 PM
Look at those burn marks! Yikes
epson 05-13-2011 05:36 PM
Well my suggestion would be as follows:
1) Drill ˝’’ holes tight together all around the existing hole and remove the debris.
2) Use a multi tool and cut your way around to make your hole larger.
3) Use a hammer and wood chisel to cut around existing hole
4) Disconnect fitting and remove cabinet if possible and drill with hole saw to desired diameter
Now I’m sure someone else will chime in and give you some more idea’s
Leah Frances 05-13-2011 06:34 PM
Ron Swanson would recommend using a Fein Multimatic.
canadaclub 05-13-2011 07:07 PM
Now , now Leah:bangin:
I never understood the purpose of enlarging the hole in the first place.
epson 05-13-2011 07:09 PM
Didn’t you know? It’s a three stooge’s classic move…:whistling2:
canadaclub 05-13-2011 07:12 PM
nyuk nyuk nyuk:whistling2:
boogerz 05-13-2011 08:13 PM
thanks for the help again naps and epson!- im a newb so i duuno why those burn marks are there. can anyone tell me? btw pliers and a knife did the trick!
epson 05-13-2011 08:22 PM
The burn marks are there because the plumber soldered the fitting to the pipe and came to close to the cabinet with his torch.
canadaclub 05-13-2011 08:36 PM
He certainly did. Like the old proverb states. "Owa-tana-siam"
jcrack_corn 05-13-2011 08:38 PM
rotozip
fein
either one would do fine, but that [birch?] plywood might not do well with the fien, probably too flimsy.
Willie T 05-13-2011 09:42 PM
I'm sorry, but we try very hard to get those holes as small as possible when installing cabinets. Who in the world ever told you that a base cabinet could fall? That cabinet is not going to fall at all.
epson 05-13-2011 09:54 PM
1 Attachment(s)
something like this?
