How To Cut The Bottom Of Hollow Interior Doors With Out Damaging The Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-20-2008, 10:13 AM   #1
how to cut the bottom of hollow interior doors with out damaging the door
I recently got new carpet in my home after they were done I was told that I would have to cut the bottom of the doors to clear the carpet. Any sugestions??
nick400012000 is offline   Reply With Quote
Old 01-20-2008, 10:18 AM   #2
how much do you need to cut off? If less than an inch, the door should be solid to at least that height.
I'd use a sharp 40 tooth blade, lay masking tape over the cut on both sides, clamp a fence to the door, and go at it with the circular saw.
NateHanson is offline   Reply With Quote
Old 01-20-2008, 10:26 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you need to cut off more, and you get into the hollow portion of the door:
I usually take the atucal "cut-off" segment, then run it thru the table saw - taking the panel-surface material off of each of the sides.
What you are left with is the actual "core" plug that was in the bottom of the door. Just install that back into the hollw area using wood glue and some pin nails to hold it in place until the glue dries.
Last, I like to take a palm sander and smooth over the cut edges a little on the bottom as well.
- Build Well -
Old 01-20-2008, 11:39 AM   #4
ICF Construction
I always mark them and then use a straight edge, run a utility knife on the top side, this prevents chipping of wood when cutting, then follow what AtlanticWB says.
Chris
Chris Johnson is offline   Reply With Quote
Old 01-20-2008, 12:15 PM   #5
Originally Posted by Chris Johnson View Post
.... run a utility knife on the top side, this prevents chipping of wood when cutting....
Good point.
I too, also use a straight edge for the cut (or 4' Level, clamped to the door slab).
- Build Well -
Old 01-20-2008, 01:53 PM   #6
Custom Cabinet Maker
Just remember to put the FACE down when using a circ saw.
skymaster is offline   Reply With Quote
Old 01-20-2008, 05:20 PM   #7
Rewards Points: 6,652
On a door, which is face side? Both sides are face.
Old 01-20-2008, 11:26 PM   #8
The "face"side is the one that FACES into the room :} the side that opens to the wall is the BACK
Old 01-20-2008, 11:32 PM   #9
But, when you close it, both sides are Face.
I just had to be ornery, due to my wife got the worst of me today while pulling wire for outlets in the Living Room. It was one of those things that I have been putting off for the past 4 years since we bought our house (70+ year old with Greenfield Armor).
Old 01-21-2008, 11:18 AM   #10
Greg: Didnt you explain that IT IS AGAINST ALL LAWS OF MANKIND ; IT IS CRUEL AND UNUSUSAL PUNISHMENT,WHICH IS AGIANST FEDERAL STATUES;
ALSO FORCED LABOR, SLAVERY To make anyone WORK for 3 weeks at minimum AFTER THE GIANTS ACTUALLY WON!!!!!!!!!!!!!!!!!!!! We need medical treatment,luv and understanding plus 30 days of OPENED beers freely served by totally obiedient woman!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PLUS yOU ARE SUPPOSED TO SWING WITH THE DOOR
That is the way I do it there is no rule about it. If it was a door that you go thru say from a great room, living room whatever then to me the face is the money side, the one that is seen most often by the most people.
that said, lay it out on both sides and CUT THRU THE VENEER WITH A NEW BLADE IN A RAZOR KNIFE on both sides, MAKE sure that you DO NOT cut above that knifecut with the saw and you should be 99% clean, the take sandpaper or a blockplane ( my way ) and raduis those cut edges and you shall be fine.
Jack
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 11:00 PM
Hollow wood door with hole where the hing plate goes earlc General DIY Discussions 4 07-08-2007 02:21 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
Hanging towel bar in hollow core door. ERIK2173 Remodeling 1 02-06-2006 08:19 PM
