Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-24-2012, 04:59 PM   #1
How come no one uses epoxy for showers?
After tiling a shower surround, wouldn't it make sense to coat the tile / grout with epoxy, both to ensure it was water tight and to keep mold from forming in the grout?
I could see epoxy being a slipping hazard on the floor, unless mixed with aggregate, but on the walls, wouldn't it make sense?
tibberous is offline   Reply With Quote
Old 01-24-2012, 05:24 PM   #2
sdsester's Avatar
Tile and mortar should be able to breathe. And, if you seal it in epoxy and you bang the stuff and create a micro crack or fissure and water gets behind it. A royal mess is suddenly created. And with good tile and mortar there is no need for it so why put out the extra expense even if it did work.
sdsester is online now   Reply With Quote
Old 01-24-2012, 05:30 PM   #3
Stuck in the 70's
Blondesense's Avatar
There are epoxy grouts that are highly stain resistant.
Old 01-24-2012, 05:36 PM   #4
Super Moderator
About all I use are epoxy grouts--I don't mention it often as they are a bit difficult to use--
oh'mike is online now   Reply With Quote
Old 01-24-2012, 07:37 PM   #5
MarginallyQualified
When you put the second Red Gard coat down... embed some nylon window screen.
Then do the epoxy coat.
How come no one uses epoxy for showers?-img_0069.jpg   How come no one uses epoxy for showers?-img_0071.jpg
TarheelTerp is online now   Reply With Quote
Paint for Rust-Prone Exterior Metal Railings (Oil-Based Metal vs Epoxy vs Urethane) Einhorn Painting 9 06-19-2011 09:41 PM
Epoxy Questions bsmith95610 Flooring 11 04-02-2011 04:41 PM
Bathtub Chipping In Bottom llg871 Remodeling 3 12-18-2008 12:32 AM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 04:55 PM
