-   -   How come no one uses epoxy for showers? (http://www.diychatroom.com/f2/how-come-no-one-uses-epoxy-showers-131260/)
tibberous 01-24-2012 04:59 PM
After tiling a shower surround, wouldn't it make sense to coat the tile / grout with epoxy, both to ensure it was water tight and to keep mold from forming in the grout?
I could see epoxy being a slipping hazard on the floor, unless mixed with aggregate, but on the walls, wouldn't it make sense?
user1007 01-24-2012 05:24 PM
Tile and mortar should be able to breathe. And, if you seal it in epoxy and you bang the stuff and create a micro crack or fissure and water gets behind it. A royal mess is suddenly created. And with good tile and mortar there is no need for it so why put out the extra expense even if it did work.
Blondesense 01-24-2012 05:30 PM
There are epoxy grouts that are highly stain resistant.
oh'mike 01-24-2012 05:36 PM
About all I use are epoxy grouts--I don't mention it often as they are a bit difficult to use--
TarheelTerp 01-24-2012 07:37 PM
2 Attachment(s)
When you put the second Red Gard coat down... embed some nylon window screen.
Then do the epoxy coat.
