Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-11-2005, 10:18 AM   #1
Question
how to clean double pain windows
:confused: I got a quick question how do clean in the middle of my double pain windows? It seems that I must dissasemble the hole window to do it, right?
Thanks in advance.
DIYER33 is offline   Reply With Quote
Old 04-11-2005, 10:15 PM   #2
aka:awesomedell
Send a message via MSN to housedocs
Are you talking about in between the panes in a single sash? If so the answer is yes. The sashes will usually tilt out for cleaning.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 04-12-2005, 06:14 AM   #3
Remodeler
MinConst's Avatar
It sounds more like double pane glass. If the glass is fogged inside then the seals have failed. There isn't much you can do except replace the glass.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 04-12-2005, 12:53 PM   #4
I might have to replace the glass if the fog stain does not come off. Thanks for your help. I might just play baseball this weekend outside my house and see I can not miss that window with the foggy view.:D
How are atrium double hung windows? bmf5150 Building & Construction 2 01-05-2008 02:50 PM
Casement versus double hung windows Sammy Carpentry 7 03-15-2007 09:21 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
Double Paned Windows cambece Remodeling 5 10-04-2006 04:31 PM
Double Glazed Windows Black Sealing Strip hansi General Discussion 2 09-08-2005 05:05 AM
