Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-27-2009, 09:16 AM   #1
How to change the lock on a cabinet i found?
I found this old explosion proof cabinet that would be great for my paint stuff and general gear storage. I plan to sand and repaint it. It has a small cylinder lock. Is there an easy way to replace this?
ocz800 is offline   Reply With Quote
Old 03-27-2009, 01:00 PM   #2
gravity always wins
Those chrome plated "L" handles are pretty standard. There may be an access plate on the inside of the cabinet door that you remove to get to the back of it. If not then you might have to remove the panel on the inside of the door. The box stores may have replacements. Garage door companies would have them. I would plan on sawing the square spindle to length on your replacement.
Went to change wax ring , but found this timewarp Plumbing 12 01-28-2009 04:10 PM
£300 to change UPVC front door lock? jojo50 General Discussion 1 10-23-2008 09:15 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 11:59 PM
