How Can I Seal Blocks To Prevent Seepage. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 10:21 PM   #1
How can I seal blocks to prevent seepage.
With the north addition on our cabin we have two blocks of the old foundation exposed. How can i stop them from seeping moisture in the rainy season? Would plaster work?
rileth63 is offline   Reply With Quote
Old 03-13-2013, 10:24 PM   #2
Rewards Points: 13,242
Plaster used inside.
If there exposed and not below ground then where's the water coming from?
rileth63 (03-17-2013)
Old 03-14-2013, 07:58 AM   #3
Rewards Points: 3,130
Is the ground properly graded so water runs away from the foundation?
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 03-14-2013, 09:56 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,768
At the end of the day, nothing you can put on the inside will stop the moisture from coming through if you have poor grading or water management outside.
If you could stop the moisture, you might create an issue with hydraulic pressures working on the building. If you can stop the moisture from coming against the side, that is ideal. If not, you will want to manage how it comes through.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 03-14-2013, 11:23 AM   #5
best way is 1 a french drain move the water away, gutters etc. 2 use laticrete hydro Ban best water proofing stuff you can find.
RTC_wa is offline   Reply With Quote
The Following User Says Thank You to RTC_wa For This Useful Post:
Old 03-17-2013, 12:45 AM   #6
great help
Thanks for all the responses. We are already in the process of dirt work & a french drain on south side of building along with guttering. The original footing is 8inches shallower on south side do the original slope of the ground. Looks as though water was being trapped as it moved under the floor. Do to the thick clay enough was being captured behind north footing to later seep through. With the excavation, guttering and laticrete hydro ban hopefully it will fix the problem. Thanks again.
Old 03-17-2013, 11:57 PM   #7
Mix plaster with white cement and add "fix it" in it, I insure you it will definitely help you
SmithTitos is offline   Reply With Quote
Safe to seal exposed cinder block wall in basement? cne24 Concrete, Stone & Masonry 4 09-20-2012 08:43 PM
do I need to seal tiles, and if so, when...? rtoni Tiling, ceramics, marble 5 03-26-2010 10:41 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 09:57 PM
To seal or not to seal tops of IPE rocketdoctor Building & Construction 3 09-20-2009 01:04 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
