How To Build Riser Steps Into Jacuzzi Tub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 04:35 PM   #1
Question
How to Build Riser Steps into Jacuzzi Tub
We purchased a home with a nice Jacuzzi tub but it's a bit high for my wife to step into. I've seen some beautiful pictures of one or two riser steps and would love to build something like them. I have attached our bathtub and circled where I'd like the steps to go. Let me know your thoughts and if there are any websites out there with instructions for building these riser steps.
Thanks for your help!
Chris
PS...here's a sample picture of riser steps:
simo711 is offline   Reply With Quote
Old 03-14-2013, 04:45 PM   #2
Could someone tell me if I'm explaining myself correctly? Aren't the steps called Riser Steps? Any suggestions?
Old 03-14-2013, 07:08 PM   #3
Rewards Points: 13,300
Why not just a simple to build platform?
To do it right with steps would involve having to take that whole side apart and rebuild the whole thing.
It would be a whole lot safer for her to sit on the side of the tub and swing her legs over the side then having to stand on the side of that tub to step into it.
simo711 (03-14-2013)
Old 03-14-2013, 08:14 PM   #4
This is a great idea...she was wanting something a bit fancy and currently does sit and swing her legs over. =-)
Old 03-14-2013, 11:06 PM   #5
Msradell's Avatar
Rewards Points: 126
That's also safer than the steps. When you step down there is a greater risk of slipping.
Msradell is offline   Reply With Quote
Old 03-15-2013, 06:24 AM   #6
DIY staff
Rewards Points: 7,174
Step are dangerous---I've removed them from every whirlpool that I've re done in the last 5 or 6 years---
Before making permanent steps===build some temporary ones and see if you like them---
Old 03-15-2013, 09:28 AM   #7
Rewards Points: 2,238
From your picture -
looks like you've got a toilet to the left -
where the red circle is -
If you put step/steps there -
You're going to encroach on the toilet.
To the right - looks like a door -
You might encroach on the door.
Try something "temporary" and see!
RF
Might want to think about "grab-bars" - "hand railing"!
rossfingal is offline   Reply With Quote
Old 03-15-2013, 11:46 AM   #8
Great thoughts! Steps could be slippery in the bathroom, at the same time it will cost much to build it entirely. What about keeping something there to go up the tub whenever you need it?
leenamark1 is offline   Reply With Quote
Old 03-15-2013, 12:56 PM   #9
Dave Sal's Avatar
Rewards Points: 598
You could go to any spa supply store and pick up a set of spa steps for less than $100. There are some made of a resin material that comes in various colors.
Dave Sal is online now   Reply With Quote
Old 03-15-2013, 01:36 PM   #10
Thanks "Dav Sal"!
They wouldn't clear the toilet or the door.
(They look good, though!)
Old 03-15-2013, 11:23 PM   #11
Rewards Points: 266
These work well in a hospital setting. Not very pretty but small, portable and not too pricey. You can just grab it by the handle and put it away in the closet when not in use. Step stool with handle.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
oh'mike (03-16-2013)
Tags
bathtub , steps
Planning to build First Spec Home, Need Advice ahb2012 General DIY Discussions 53 05-27-2013 07:30 AM
Isn't 8" riser height too big? cvstan Building & Construction 30 07-10-2012 11:38 PM
How much more would it cost to build another story? reveriereptile Building & Construction 5 01-19-2012 11:51 PM
Refacing my cement front steps - I have a question Sephora Building & Construction 9 08-08-2011 10:58 AM
Question on front steps? flyerman22 Building & Construction 1 04-23-2007 07:53 AM
