How To Build This Horizontal Plank Fence - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 01:03 PM   #1
Rewards Points: 278
how to build this horizontal plank fence
I need to replicate a fence similar to this one to match the property
can someone help me understand how it is built?
Especially the horizontal planks, it appears the planks are symmetrical on both sides (there is a plank on each side butting at a inverted V angle) Looking closely these planks are nailed at an angle into the posts. but I wanted to know if the planks are mitered or what other prep was done make them slanted.
DIYGST is offline   Reply With Quote
Old 01-08-2013, 03:40 PM   #2
remodeling pro
Could you do a better/closer pic? Do you mean that the planks are overlapping like clap board siding?
troubleseeker is offline   Reply With Quote
Old 01-08-2013, 03:48 PM   #3
Rewards Points: 14,312
That's what it looks like to me to.
Old 01-08-2013, 03:50 PM   #4
Rewards Points: 278
It does look like a siding, but it is the same look on both sides.
Old 01-10-2013, 11:15 AM   #5
Rewards Points: 26
Scroll up to the top on this page.. click on the woodworking tab.. it will take you to another forum that's operated by the same folks as this one.. You'll need to register & do a quick intro then hit the general woodworking section with your question.
Tons of very knowledgeable folk there that will help ya right out.
You might want to get some close up shots of the joinery.. It could be mortice & tennon or it might be set in a dado. Hard to tell from the distance of your photo.
Dados are usually square channels not a "V" groove.. Swing over to woodworkingtalk & ask a bit..
Good Luck.
..Jon..
J Thomas is offline   Reply With Quote
6' wood privacy fence questions snosurfa7 Landscaping & Lawn Care 13 06-01-2012 01:45 AM
Wood Fence - Competitive Bids and DIYer screamon demon Carpentry 10 05-25-2011 09:02 AM
Advice needed on staining wood fence deerhunter Painting 0 10-29-2010 10:27 PM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 08:05 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 03:39 PM
