How To Best Cover Weep Holes On A Brick Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 07:00 PM   #1
How to best cover weep holes on a brick wall
What is the best way to cover the weep holes on a brick house? I've been fighting ants that like to use them for highways and don't want other bugs crawling in to make a nest. My dad just uses silicone and a piece of screen to cover them. Is there anything better that ants will not go through?
Thanks in advance,
Stan.
smcmurrey is offline   Reply With Quote
Old 06-05-2008, 07:11 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Weep holes are there for a reason. I wouldn't cover them up.
As for keeping ants out, I hear they won't cross a line of citrus oil.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-06-2008, 09:21 AM   #3
Rewards Points: 1,232
Stuff them with stainless steel wool (like scrub pads). Do not under any circumstance close them off to air.
Tscarborough is offline   Reply With Quote
Old 06-06-2008, 10:07 AM   #4
Underground Techie
sevver's Avatar
What about rope? That seems to be how I have seen them in the past. I would not think that they are there for air ventilation, more in case water were to get behind there, right? Doesn't the foundation step up behind it where the sill goes?
sevver is offline   Reply With Quote
Old 06-06-2008, 10:13 AM   #5
angus242's Avatar
Yes, on newer construction I've seen rope in the holes that the masons use while laying the brick. I was going to suggest the same (soaked in citrus oil!!!!)
Angus
My Albums
Old 06-10-2008, 06:57 PM   #6
Where do you get citrus oil? I checked at Lowes and they didn't know either.
Old 06-10-2008, 07:10 PM   #7
angus242's Avatar
Perhaps a larger nursery in your area. Also the chemical name for citrus oil is d-Limonene so check for that too.
Angus
My Albums
Old 06-10-2008, 08:12 PM   #8
If you use cotton rope soaked in citrus oil, you are not doing any good. You may as well plug them with mortar. I have already told you the correct way to fix it.
The Following User Says Thank You to Tscarborough For This Useful Post:
concretemasonry (10-12-2011)
Old 06-10-2008, 09:29 PM   #9
Thanks, I'm planning to try the citrus oil just to see if it will stop the ants. I found some fine stainless steel screen with tiny holes that I cut into patches. I plan to use clear silicone to glue them over the holes. The holes are so small I'm not sure ants can get through it, pretty sure the queen can't get through so they should not nest in the wall. Thanks for all the advice. Stan.
Old 06-10-2008, 09:34 PM   #10
angus242's Avatar
Why do you say rope is like mortar? Or is there something else I'm missing?
Angus
My Albums
Old 06-10-2008, 09:35 PM   #11
Stan, why make it harder than it is? Take some stainless steel wool, twist it down into a pointy rod and stick it in the hole. Done! Forever! No reapplying citrus, no ugly ass silicone patches that peel off in a year, and no mold from clogging the weeps.
Old 06-10-2008, 09:35 PM   #12
I figured I'd add a bit more to what I found through my searches. I couldn't see spending over $100 for store bought covers when I found the SS screen real cheap so the whole job may end up costing $15.
I think this is the best looking store bought product I found.
http://www.bugoutweepholes.com/articlesquotes.html
Old 06-10-2008, 09:38 PM   #13
Do you think ants can still get through the steel wool? I have some and may try it out. Right now there are so many ants trying to get in that I could put one of each up and see which one keeps them out.
Old 06-10-2008, 09:47 PM   #14
No they won't get through it. Here is an example:
http://stores.sobodistribution.com/Detail.bok?no=411
Do you have head joint weeps or tube weeps (how big is the hole?)
Old 06-10-2008, 10:23 PM   #15
The mortar was left out between two bricks along the bottom row so the gap is about 3/8"x3.5" tall. About every third brick has a hole.
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 02:45 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 09:09 AM
