How To Attack This... (insulation Related) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 04:39 PM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
How to attack this... (insulation related)
Well, leaving for work the other day I noticed the dew on the roof had evaporated in one spot faster than the rest of the roof and I found that funny.
Luckily it was fairly easy to investigate since the spot on the roof directly corresponds to the crawlspace behind the wall in our guestroom.
As you can see the insulation there is kind of a mess.... hence... I'm here asking for advice.
What do you think? Tear out & start over? Or try to fix this mess?
How to attack this... (insulation related)-insul_1.jpg   How to attack this... (insulation related)-insul_2.jpg   How to attack this... (insulation related)-insul_3.jpg
CoconutPete is offline   Reply With Quote
Old 10-31-2010, 05:19 PM   #2
Rewards Points: 5,336
The insulation should be on the door wall, under the plywood behind the door and the ceiling. There should be no insulation in the roof rafters behind the door.
Check out the Owens Corning site for a visual of the proper installation on the second floor.
Ron
Old 11-01-2010, 12:19 AM   #3
Registered User
Rewards Points: 4,912
Use rigid insulation board or a house wrap on the attic side of the knee wall and insulate the attic access door, as mentioned already: http://www.simplesavings.coop/simple...ee%20walls.pdf
Gary
Old 11-01-2010, 08:51 AM   #4
Rewards Points: 504
Interesting. Was it done differently back in the day? The knee wall right now has absolutely zero insulation on it, but the roof rafters is where it was all insulated. It's a cape cod from 1930.
I guess a side question becomes: Tear out the old insulation in the picture?
Old 11-01-2010, 09:25 AM   #5
My roof rafters are insulated w/R25
My knee walls are insulated w/R13 to R19
My preference is to insulate both
My storage area stays warmer then outside
Since there is living area below the storage area it makes sense
Old 11-01-2010, 09:32 AM   #6
Rewards Points: 504
Which one do you like better:
A: Try to "mend" the insulation that is in the rafters and then insulate the knee wall.
B: Tear out the insulation in the rafters and start fresh both there and in the knee wall.
Old 11-01-2010, 09:42 AM   #7
That depends upon the rafter size & existing insulation
Also if the soffit/ridge are vented & you have rafter vents installed
R25 was installed by a prior owner in my rafters
Does not make sense to me to rip mine out to go to R30
But if you have R13 & can fit R30 that would be much better
Old 11-01-2010, 10:30 AM   #8
Rewards Points: 504
I'll inspect it more thoroughly tonight.
Only the first 5 feet have come apart, it doesn't appear those particular soffits are vented but we'll see.
Old 11-01-2010, 11:08 AM   #9
Ron
Why would you not insulate the rafters? This is a storage area. If it were an open attic I would agree, but it is not. Insulating this area would not cause the dew on the roof to evaporate more quickly, it would be the opposite.
1) Make sure the proper ventilation has been maintained
2) Repair the insulation as needed. The purpose of the paper on the insulation is a vapor barrier so you can use the existing insulation in place just use insulation or vapor barrier tape. If you can get to all of the seams, you should tape them as well. Most areas in the
3) Insulating any interior knee walls with R13 or R15. R19 in 2x4 walls compresses and only give you an R13 value.
TNTRob is offline   Reply With Quote
Old 11-01-2010, 06:27 PM   #10
Registered User
"Was it done differently back in the day? The knee wall right now has absolutely zero insulation on it, but the roof rafters is where it was all insulated." ------ No, it's the same. Look again at the site I used, notice the top circled picture- just like you are describing. No floor insulation, no wall insulation, just in rafters. It all depends on where you want the thermal envelope: http://www.homeenergy.org/archive/he...95/950309.html
Gary
Old 11-01-2010, 10:55 PM   #11
Rewards Points: 504
Gary: That's a good site, I'm going to read that tomorrow. For some reason I completely missed your first post when I was reading the thread on my phone earlier.
For now, just a couple of pics. The inside wall is made from 2x4's.
The rafters measure 5.5" which I finally have figured out means 2x6 in the United States
It's a mess in there, I think cleanup will be step 1 - I never realized how BIG that space is. Seems it would make a wonderful storage alternative to the detached garage attic.
How to attack this... (insulation related)-insul_11.jpg   How to attack this... (insulation related)-insul_09.jpg
Old 11-03-2010, 08:40 AM   #12
Rewards Points: 504
Well it seems insulating the kneewall might not be the best in this scenario. In 2 different locations, ductwork pops up from the basement on the left side of the last picture I posted and runs across the kneewall floor, through the wall into the bedrooms. If I move the boundary to the kneewall, teh ducts are going to be in a cold zone.
Old 11-03-2010, 10:12 AM   #13
The ducts should be insulated. If they're behind the knee wall they're in a cold zone already. There is nothing you can do behind the knee wall, insulation wise, that will compensate for uninsulated ductwork.
These are 2 separate but related issues.
Ron
Old 11-03-2010, 10:16 AM   #14
"The ducts should be insulated. If they're behind the knee wall they're in a cold zone already. There is nothing you can do behind the knee wall, insulation wise, that will compensate for uninsulated ductwork.
These are 2 separate but related issues."
I think Ron hit the nail on the head, so to speak. I've done a lot of insulation work and the ducts should be insulated, and as far as the knee wall is concerned, you're SOL my friend.
________________________________________________
Bob Burns
roofing dallas
bobburns is offline   Reply With Quote
Old 11-03-2010, 10:31 AM   #15
Rewards Points: 504
If the rafters are insulated (what's left of it anyway) and there's living space beneath the side attic, then how is it considered a "cold zone"?
If the kneewall was insulated and the rafters were not then yes I could understand that, but with no insulation in the kneewall and the rafters insulated wouldn't that move the barrier past the kneewall?
By the way, the ducts are insulated, you can see them in the bottom of the pic - looks like asbestos (fun).
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
mobile home related metal roof insulation chris313scorpio Building & Construction 0 09-28-2010 10:29 AM
Garage insulation - to replace or not, and related questions DaveinGA Remodeling 6 12-20-2009 11:25 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
