How To Attach Two Beams At 45 Degree Angle On Top Of 4x4 Post? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-14-2008, 09:11 AM   #16
Rewards Points: 230
Originally Posted by BuiltByMAC View Post
Oops. Misread your OP...
Try these - Simpson AC4 (AC6 if you have 6x6 posts)
The top wings can be bent into shape. Put one on each side of your post...
Mac
Thanks. That's actually what I was thinking about doing. Lets hope it works.
Ler0y Jenkins is offline   Reply With Quote
Old 06-02-2008, 04:16 PM   #17
Rewards Points: 230
See below.
How to Attach Two Beams at 45 Degree Angle on top of 4x4 Post?-45-degree-intersection.jpg
Old 06-02-2008, 04:16 PM   #18
Rewards Points: 230
I've designed a method where I'll use a 6x6 for the post in question and notch it out according to this diagram:
I'll just drill four holes through the back of that post (two on each beam) and use some through-bolts to secure it. What do you guys think?
Old 06-02-2008, 05:49 PM   #19
Registered User
Termite's Avatar
That's what I was suggesting in my post. Works great.
Old 06-02-2008, 06:36 PM   #20
Lansing's Avatar
Yes that should work very well...Do use washers with your bolts ...I would put some type sealer on the wood parts of the post you cut before you set in your 2x8's...Just a thought...
When the time comes for you to leave this world
the only thing you get to keep is what you gave away...
Lansing
Lansing is offline   Reply With Quote
Old 07-17-2008, 06:46 PM   #21
Doing the same thing here.
Doesn't the beam have to set a certain amount on the post?
Chris CA is offline   Reply With Quote
Old 07-18-2008, 07:48 AM   #22
Rewards Points: 230
Here's a picture of how it came out from my other deck-building thread:
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 04:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
