How To Add A Door Stop To This Hinge? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 05:40 AM   #16
biggles's Avatar
magnets.... mount one onto that floor register then a strip piece onto the bottom edge of the door.so when it swings back they lock up on each other. http://www.knobsandhardware.com/door-stops_707.html
Old 07-29-2012, 07:47 PM   #17
Rewards Points: 558
Originally Posted by jschaben View Post
That's true, but not all pins are removable, at least not without destroying the hinge. Some are made that way for security purposes and some just for cheap manufacturing purposes.
The security hinges usually have a small set screw holding the pin in place. I donít think the hinge that he has in place are cheap hinges.
epson is offline   Reply With Quote
Old 07-29-2012, 08:24 PM   #18
jschaben
Rewards Points: 502
I don't think they are particularly cheap hinges either. Taking a closer look at the pic and rereading the original post, I wonder if they aren't partially threaded and removed with an internal hex or torx wrench. Could even be a security torx. If that's the case though, I doubt there would be enough thread in there to add a hinge mounted door stop. I think in this case, I would be looking at an angle bracket that would mount to the wall or door jam behind the hinge and stop the door there.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-29-2012, 08:50 PM   #19
Rewards Points: 558
If the op really wants to know what type of hinge he has and how to remove the pin, then may I suggest to remove the hinge and taking it to a security hardware place in his area to give him his answer.
Old 07-30-2012, 12:25 AM   #20
In a little over my head
Rewards Points: 706
Why not just screw/glue a wedge to the top of the door, so the wedge hits the trim, just like a hinge mounted stop?
ratherbefishing is offline   Reply With Quote
Old 07-30-2012, 01:35 PM   #21
Too Short? Cut it Again!
Had a fromer firefighter as a client who invented a thing called the HookCheck. Firefighters have obvious reasons for needing to keep doors open and he found it easy to trip over things on the floor or screwed into the wall.
The hook check was a simple patented wedge with a retractable metal hook. You hooked it between the door and frame and it was out of the way and held the door open nicely. The things were so strong you could pull a door apart forgetting it was there though.
Not sure if you can still get them online or not.
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
door hinge into a plaster wall? dbpass Remodeling 1 05-04-2011 12:49 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 12:00 PM
