How To Add A Door Stop To This Hinge? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 07:42 PM   #1
How to add a door stop to this hinge?
Hello,
I have a new ply gem door that I can't figure out how to add a hinged door stop. No other solution will work in my situation. The hinge is different in that it doesn't have a traditional pin. A pin is up inside and I can't seem to get it out. There is a rubber piece that accepts a 3/16" pin. The bottom side seems to have a head that could accept an Allen wrench. Has anybody dealt with a hinge like this. The manufacturer was no help when I called.
Thanks,
Jeff
Jhschlak is offline   Reply With Quote
Old 07-24-2012, 09:11 PM   #2
Rewards Points: 6,652
You don't. You just have to put a stop on the floor, or on the baseboard, to keep it from hitting the wall. Floor stops are better, and will stand up to someone slamming the door inward.
Old 07-24-2012, 09:19 PM   #3
I would like to but the door is elevated too high off the floor for a floor bumper and when I open the door it opens into another glass window. The glass window is actually a fixed french door and i would not want to drill into it. This is quite frustrating. We are using pillows right now. Ha.
Jeff
Old 07-24-2012, 09:52 PM   #4
Then my only suggestion is to teach people not to slam doors as they open them. You could probably change out the hinges if you wanted to, if you can find any that will fit in the same routed cutouts.
Old 07-24-2012, 09:57 PM   #5
I think if I can figure out how to get the pin out, I could retrofit some type of stop into it. Anybody know how to get the pin out?
Thanks,
Jeff
Old 07-24-2012, 10:11 PM   #6
It is made that way to keep people from getting the pins out. Have you read the instructions that came with the door, if you have them, or contacted the manufacturer about removing the pin? If it is made to be threaded, doubt there is enough length to allow you to put one of the cheater door stops on the top anyways, so your only best bet would be to change out the whole hinge.
Old 07-27-2012, 04:12 PM   #7
Craftster
ghostlyvision's Avatar
Rewards Points: 95
Would a stop like this attached to the baseboard work?
http://absupply.net/486-angledoorstop.aspx
ghostlyvision is offline   Reply With Quote
Old 07-27-2012, 05:20 PM   #8
Rewards Points: 2,202
That attaches to the floor, hmmm attached sideways to the base, the tip would end up hitting
mae-ling is offline   Reply With Quote
Old 07-27-2012, 08:51 PM   #9
I know that we have lost the OP by now, there appears to be other heights available on that site. http://absupply.net/trim-auxiliary-d...hold-open.aspx
Old 07-28-2012, 11:38 AM   #10
In a little over my head
Rewards Points: 706
Rubber flower pot weighted with cement?
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
mae-ling (07-28-2012)
Old 07-28-2012, 10:52 PM   #11
jschaben
Rewards Points: 502
Might work, attached to the door jamb right behind the hinge.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following 2 Users Say Thank You to jschaben For This Useful Post:
ghostlyvision (07-29-2012), mae-ling (07-28-2012)
Old 07-28-2012, 11:54 PM   #12
Rewards Points: 558
try something like this:
epson is offline   Reply With Quote
Old 07-28-2012, 11:59 PM   #13
Neat stop, but my understanding is the pins do not come out on these hinges.
Old 07-29-2012, 12:09 AM   #14
Rewards Points: 558
As far as I know, all hinges have some sort of pin to hold the two parts together.
He can also take a look at this site. http://www.doorsaver.com/index.html
Old 07-29-2012, 05:30 AM   #15
jschaben
Rewards Points: 502
That's true, but not all pins are removable, at least not without destroying the hinge. Some are made that way for security purposes and some just for cheap manufacturing purposes.
John Schaben
The Following User Says Thank You to jschaben For This Useful Post:
mae-ling (07-29-2012)
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
door hinge into a plaster wall? dbpass Remodeling 1 05-04-2011 12:49 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 12:00 PM
