House Built In 1930 But No Plaster? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 05:09 PM   #1
Rewards Points: 83
Our house was built in 1930 but there are absolutely no traces of any plaster on or in the walls, i have been inside about half of the walls now and there is no evidence that plaster walls ever existed in this house, not even plaster dust.
Our walls are this press board stuff, kind of light brown in color with no paint or wallpaper then covered with crappy 70's paneling.
So what gives, if the house was built in late 1929 wouldn't you expect it would have been built using lath and plaster?
Our kitchen had what was like double spaced lath with paneling nailed to it. No trace of plaster or white dust anywhere inside the walls though.
linuxrunner is offline   Reply With Quote
Old 06-28-2011, 05:22 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope, not necessarily. I've seen something like that before. Sort of a pressed cardboard-like product.
It's the "panelling" that is surprising if it is original equipment of the period.
XXX
Old 06-28-2011, 05:35 PM   #3
Rewards Points: 6,652
It depends on who they purchased the home through. Also, since you are in Or., it would not surprise me that the home was built for workers for a nearby mill or such. Any stamp marks on any of the attic or timbers used for the joists? You can do a search on the style of the home with year through a search engine, or check local library, or even platt info on your taxes for the home, which could give light who built the neighborhood, and where homes were ordered through.
Old 06-28-2011, 05:40 PM   #4
kwikfishron's Avatar
Rewards Points: 344
Bud, what's a Trops?
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Bud Cline (06-28-2011)
Old 06-28-2011, 05:46 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well CRAP!!!
Beats the hell out of me. Guess I'll go fix it.
Thank You
XXX
Old 06-28-2011, 05:48 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is that better?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
kwikfishron (06-28-2011)
Old 06-28-2011, 08:16 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Are you guys talking about celotex panels. Lightweight, kinda look like a fiberboard? My house is 100 years old. Sometime in the 40's they covered part of the walls with celotex.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
gregzoll (06-28-2011), linuxrunner (06-28-2011)
Old 06-28-2011, 11:33 PM   #8
Rewards Points: 83
it's a stone house that was built by a family of stone masons (was their personal house), that immigrated to Portland to build some local stone structures (or at least that's what we were told).
Is it possible that since the walls are stone they were unable to use plaster? if i remove the pressed cardboard paneling you can see the stone walls.
So it sounds like various types of paneling were available prior to 1930? Any idea if these would have been cheaper or easer than lath and plaster?
Old 06-28-2011, 11:54 PM   #9
Rewards Points: 83
Besides the pressed cardboard stuff the other paneling is like a thin plywood but very decretive kind of like beadboard but a totally different pattern. Even the ceiling is a type of rectangular panel that fits together.
Here are some pics of the other type of paneling (not the 70's stuff) and the ceiling. Do these look original?
Old 06-29-2011, 05:05 AM   #10
paper hanger and painter
chrisn's Avatar
Rewards Points: 294
No, my house is stone and all lath and plaster( 1924). I think it is just some original form of "drywall" used back then to avoid the cost of "real" plastering.
Old 06-29-2011, 08:56 PM   #11
Gymschu's Avatar
Rewards Points: 646
In your pics, those panels look like marlite or masonite..........there were other trade names also. It has a smooth/glossy finish coated onto a black/brown type of pressboard. As for your lack of plaster, I have seen that stuff before on homes built in the 20's, and, yes it seemed to be a type of early drywall.
Old 06-30-2011, 06:04 AM   #12
chrisn's Avatar
Rewards Points: 294
[quote=Gymschu;676899]In your pics, those panels look like marlite or masonite..........there were other trade names also. It has a smooth/glossy finish coated onto a black/brown type of pressboard. As for your lack of plaster, I have seen that stuff before on homes built in the 20's, and, yes it seemed to be a type of early drywall.[/quote]
Yes!
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
dealing with exterior slope towards house. organick Building & Construction 26 03-19-2011 02:57 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 05:58 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
