Hot Water Tank Issues - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-18-2014, 12:36 AM   #1
Hot water tank issues
We installed a new electric hot water tank and it gets hot but isn't getting hot in shower. Thermostat at max. Same tank as before just new one. Even replaced new one with this one and same issues. We did install a new cold water pressure tank. Have well. House was replumbed 3 years ago with flex pipe overhead. Any ideas?
bsracing is offline   Reply With Quote
Old 05-18-2014, 02:18 AM   #2
Rewards Points: 422
Yes, I have an idea. During the heater change out a piece of debris dislodge and flowed to the shower valve disrupting its normal operation.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
ben's plumbing (05-18-2014), bsracing (05-18-2014)
Old 05-18-2014, 02:18 AM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by bsracing View Post
We installed a new electric water heather...
...it gets hot but isn't getting hot in shower.
Any ideas?
1) define hot
2) does the shower have a thermostatic valve?
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 05-18-2014, 06:11 AM   #4
Rewards Points: 274
I think you can consult with expert in this regard.
alexjoe is offline   Reply With Quote
The Following User Says Thank You to alexjoe For This Useful Post:
Old 05-18-2014, 07:10 AM   #5
Rewards Points: 12,824
Never should turn the thermostat on the heater up all the way!
If the water is hot (should be no more then 120 deg.) everywhere else in the house then there's trash in the anti scald (also called the balancing valve).
Anytime major plumbing work is done like that the lines should have been flushed out starting with the outside faucets, aerators removed on the faucets and water ran through them.
That way the trash gets pushed out before getting to the shower control.
Old 05-18-2014, 01:17 PM   #6
Rewards Points: 808
is it plumbed backwards?
IslandGuy is offline   Reply With Quote
The Following User Says Thank You to IslandGuy For This Useful Post:
Old 05-18-2014, 03:43 PM   #7
Rewards Points: 1,002
1) As per Island guy, it is drawing from the dip tube
2) The mixing valve isn't getting all the way over
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Old 05-18-2014, 04:25 PM   #8
Where is the mixing valves in the shower? Your help is appreciated.
Old 05-18-2014, 06:36 PM   #9
Rewards Points: 582
it plain to see problem developed after heater change out....debris is probley the problem as fairview mentioned...
Old 05-18-2014, 10:13 PM   #10
Normally on the wall, with a handle attached
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 08:37 AM
Concrete tank for solar water preheating? Badfish740 Building & Construction 5 03-09-2010 09:20 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
