Hot Water Issues - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 04:11 PM   #1
Hot water issues
Hello.
I have hot water through out the house except in the masterbath shower. I can only get it up to lukewarm. What could be causing this?
thanks.
rmsnow
rmsnow is offline   Reply With Quote
Old 11-15-2010, 05:25 PM   #2
Rewards Points: 5,336
Originally Posted by rmsnow View Post
Hello.
thanks.
rmsnow
What sort of shower controls do you have? Pressure balanced? The older 2 handle unit?
Sounds like there's a blockage on the hot water side if the sink has hot water.
Do you know how to take these things apart?
Ron
Old 11-16-2010, 06:50 AM   #3
Pressure balance faucets(single handle) have a mechanical stop adjustment inside to limit hot water. Not all are same, but it is usually a gear type plastic ring thatyou set for hot flow.
You don't have to turn off the water to set this. Unscrew the handle, and you should see the stop mechanism. There may be markings to indicate hotter/colder max settings.
Old 11-16-2010, 12:39 PM   #4
And Still Learning
If this just started happening it could be that your "Hot Water or Cold Water" is colder. Still will have to reset the limit stop for more hot. I would guess that something has slowed the flow of your hot water.
Iron pipes?
Know It ALL is offline   Reply With Quote
Navien CR-240a tankless water heater issues PoWn3d_0704 Plumbing 20 05-07-2013 07:09 PM
water supply issues (sediment/rust/blockages) hockeytown9 Plumbing 7 07-24-2010 12:29 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water pressure issues.. land234 Plumbing 3 08-16-2009 07:16 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
