-   -   Hot water heater getting VERY hot all of a sudden today (http://www.diychatroom.com/f2/hot-water-heater-getting-very-hot-all-sudden-today-125496/)
bgbrown125 12-03-2011 06:19 PM
Greetings
Today, my hot water has become extremely hot. This started today.
Any thoughts on what causes it to essentially heat unregulated? If so, what is the remedy?
My thoughts were around something sticking or maybe the thermostat failing....
Barry
PoleCat 12-03-2011 06:31 PM
Gas or electric? You're probably right about the stat going south. You may have two seperate stats on a dual element electric WH
bgbrown125 12-03-2011 07:39 PM
More Info
The H2O heater is an electric Intertherm 50 gal
user1007 12-03-2011 10:34 PM
Have you bled the crud out of the bottom?
DannyT 12-03-2011 10:52 PM
could be a stuck thermostat (usually the bottom one in my experience), or a shorted element. usually after getting very hot water you will get no hot water because it tripped the high limit breaker in the upper thermostat. did you check to see what the thermostats were set at?
ben's plumbing 12-03-2011 10:53 PM
how old is heater..
DrHicks 12-03-2011 11:16 PM
We could speculate exactly what it is, but it's pretty much a given that your thermostat and/or your heating element(s) have gone wonky.
Most electric water heaters have two thermostats and two heating elements. You can replace all of them for about $50. That's what I did with my AO Smith about a year ago. Drained it once, and replaced both thermostats and elements.
bgbrown125 12-03-2011 11:20 PM
It is 11 years old and is fed well water in the NC mountains
bgbrown125 12-03-2011 11:22 PM
I have not done anything to it yet. Would I be better off to replace entire heater?
ben's plumbing 12-03-2011 11:28 PM
don't know if you want to spend any money on a 11yr old heater..if you can't replace thermostats by your self contractor would cost you 150-250.00 to repair...was it ever drained off the bottom to remove sediment...all have a bearing on it... get cost of new heater verses repair ...
DrHicks 12-03-2011 11:35 PM
What kind of warranty would you give, if you were to replace the thermostats and elements? Could you really even give one? I'd think that would put you at an almost guaranteed loss.
user1007 12-04-2011 08:53 AM
My California home was 4,000 sf or so ranch and with one huge water heater plunked in a corner of the garage. It was not far from washer, dryer, and dishwasher but it took hours for cooled down water to get out of the way down the 150 or so feet to the shower heads so you could take a warm or hot shower. And California has horrid hard water that even with flushing of tank water heaters does them in, in about 3 years max.
I finally shifted to Bosch, tankless, on demand, water heaters. Of course, back then, they cost me. There are probably better alternatives. Anyhow one unit went in place to serve the bathrooms. A smaller one provided hot water to the kitchen. They were properly maintained and installed by a real plumber so the 50 year warranties kicked in. Actually all major plumbing on my projects, personal and for others, was installed by Bubba plumbers.
I didn't notice major energy savings some claim with on demand. I had to shift from natural gas to electric just to start. I do know I stopped having to replace thermostats, heating elements or complete water heaters.
I sure saw an immediate dip in water use. And it was great to sleep 15 extra minutes, turn the hot water handle and have an immediate hot water shower. Even with the significant other steaming herself for like an hour or something in the jacuzzi.
Some giant, white monolith miles away in the corner of the garage was not acting up and holding me hostage because it did not feel like boiling water.
bgbrown125 12-04-2011 10:35 AM
I can replace the items discussed. But, I can get a new one for approx $300 w/6 yr warranty and I can install it my self . What do you guys think of that solution.?
Big Stud 12-04-2011 10:44 AM
Go for it. I would replace one that old.
Ironlight 12-04-2011 10:46 AM
I think that is a no brainer given your heater is 11 years old. My philosophy with water heaters is that after 10 years you are living on borrowed time. Immediately replaced the 11 year old heater in our new-to-us house when me moved in 8 months ago as there is no floor drain in the basement where it is and we are using the surrounding area for storage.
