Hot Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-20-2014, 08:19 PM   #1
Hot Floor
I live in a 2-story condo and recently noticed the tiles in my kitchen and first floor bathroom are very warm. There are no noticeable water leaks what could be the cause?
laurie123 is offline   Reply With Quote
Old 05-20-2014, 08:47 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
Do you have floor radiant heat?
Robpo is offline   Reply With Quote
Old 05-20-2014, 09:53 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is there a basement?
Are there heat ducts in the floor?
Where is your hot water heater?
Stick your ear in a glass-glass sealed tightly against the side of your head and then firmly press the glass on the lavatory faucet and hold your breath for a few seconds. Do you hear any kind of hiss? Now do the same thing on the floor...do you hear a hiss there?
The Following User Says Thank You to Bud Cline For This Useful Post:
gregzoll (05-20-2014)
Old 05-20-2014, 09:56 PM   #4
Rewards Points: 6,652
Hmm. Maybe Sunlight shining through Windows. Do you run Air Conditioning, or just open windows when home? Where are you located?
Old 05-20-2014, 10:33 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,790
Now... send us a picture of you doing that.... just so we can analyse it...
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
