Hot Dipped Vs. Exterior Galvanized Nails - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 01:58 PM   #1
Hot Dipped vs. Exterior Galvanized Nails
I hope I posted to the correct forume site. I am shopping for ring shank nails and I noticed a particular brand carries both hot dipped galvanized nails and exterior galvanized nails. The latter (exterior) is a bit cheaper. Can anyone tell me what the difference is between the two nails? From my gut the hot dipped galvanized probably provides better protection from the environment.
Shuriko is offline   Reply With Quote
Old 06-17-2012, 02:03 PM   #2
Rewards Points: 13,450
What do you plan on doing with them?
Old 06-17-2012, 02:10 PM   #3
Civil Engineer
Rewards Points: 4,694
Without knowing the specific brand and model of nail, it is impossible to determine the difference. Hot dipped galvanization is a process for putting a zinc coating on steel. Exterior galvanized nail is a description of a type of nail, and does not on its face describe the galvanization process used on the nail. If it is less expensive than hot dipped, it may refer to electrogalvanization, a less expensive process than hot dipped galvanization, which deposits less zinc on the steel, and is likely to produce a nail not suitable for use with pressure treated lumber.
Old 06-17-2012, 02:24 PM   #4
I am replacing some of my old cedar siding with same. The brand is Grip-Rite. The recommendations from the cedar industry group is to use hot dipped galvanized, but I came across both the hot dipped and exterior galvanized nails and I was just wondering for future purposes. For my project I am going the route of the hot dipped.
Old 06-17-2012, 02:53 PM   #5
kwikfishron's Avatar
Rewards Points: 392
What it comes down to is the more Zink that is coated on the steel (nail) the better it’s protected.
This is one of those things where you can hold two brands in your hand and see which has a thicker coat.
The Zink on a electrostatic galvanized nail is so thin you can’t even tell it’s coated with anything and are junk imo.
The galvanized nails I buy out of the bulk bin at the lumber yard will sometimes have clumps of Zink hanging off them, obviously well coated.
The Grip Rites in the 1&5lb boxes I see in the hardware store will work fine for what you’re doing as long as you’re not near the Ocean in which case you should be using Stainless Steel.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (06-17-2012)
Old 06-18-2012, 08:05 AM   #6
Thanks all. For this project I am using the hot dip for the added protection. I am no where near the ocean so SS is not necessary.
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 06:44 AM
nail guns & nails koodawg Tools 4 12-06-2010 10:05 PM
Forgot to use galvanized nails... healeypd Building & Construction 8 05-12-2009 09:10 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
