Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-17-2012, 09:02 PM   #1
Horizontal window blinds that are too long
Is it possible to reduce the length of horizontal window blinds?
Width is fine, but the window is only 36" tall and the blinds when fully extended is 72" long.
So for years they simply had the bottom part of the blinds drawn up and sat on the sill.
It seems like it should be possible to remove all the excess pieces and turn it into a shorter version?
I have four windows (one pair for each) so a total of eight of these. Not sure if this is a simple thing to do?
miamicuse is offline   Reply With Quote
Old 07-17-2012, 09:05 PM   #2
With out at least a picture how would we know?
Are they mini blinds?
Old 07-17-2012, 09:06 PM   #3
sdsester's Avatar
With most and some patience, you can remove slats from the bottom. Look online for instructions. Of course you want to keep the bottom piece and keep the pull cords on both sides equal.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
mae-ling (07-18-2012)
Old 07-18-2012, 05:37 PM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Are they just "regular" blinds? If so, then yes it's pretty easy - my mom tasked me with it for the first time when I was 10 yrs old.
If they are some sort of fancy blind, then I don't know.
CoconutPete is offline   Reply With Quote
Old 07-19-2012, 10:40 AM   #5
biggles's Avatar
if there mini-blinds style.just drop them down full 72" take a scissors and cut all the strings left to right horizontally 6" below that window.slide out the single blind leaving the strings hanging.see those pull ropes they need to go in the header bar with a knot..and push in button...go on YOUTUBE there are instruction videos for a visual..just watch the cutting it is critical to that ajustment.the ropes that pull the blinds and the thinner rope that hold the individual blind sections
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
Automating Window Blinds Toe Interior Decorating 2 01-06-2012 12:14 AM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
