Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-09-2012, 09:11 PM   #1
Horizontal Wall Crack
I have a horizontal crack in the foundation wall that I'd like some thoughts on:
1. Crack runs approximately 8 feet long. It is 4 feet from the ground at its peak and 3 feet from the ground at its lowest pint.
2. The crack is definitely hairline with no more than 1/16 inch crack.
3. No bowing is noticed with a 4 foot ruler...maybe 1/4 inch but couldn't tell if it was just flimsy ruler...don't have long enough level.
4. Crack runs up and down with no real pattern.
5. FYI...wall is painted brown and that's when I noticed it.
6.Ive now marked the crack for record purposes,
7. House is 22 years old.
So the big question....should I worry? Why or why not?
Gerard.
Horizontal Wall Crack-image-3164609603.jpg   Horizontal Wall Crack-image-1927318420.jpg   Horizontal Wall Crack-image-483965730.jpg
gerardswork is offline   Reply With Quote
Old 01-09-2012, 09:18 PM   #2
Forget about it. As you said the house is 22 years old, there's no waterleaks so do not mess with it. Foundations crack all the time, most often with a few years of being built. It could have been there a very long time and you just never noticed it.
Old 01-09-2012, 09:34 PM   #3
Disabled wood vet
titanoman's Avatar
Like Joe said.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-10-2012, 03:11 AM   #4
looks like a shrinkage crack as the concrete cured. I regularly see similar looking cracks in floor slabs etc.
mgp roofing is offline   Reply With Quote
Old 01-10-2012, 10:55 AM   #5
Looks like a shrinkage crack. Was probably there since the house was built. They usually start at a corner or window. I wouldn't worry about it, though water could possibly penetrate at some point.
mikegp is offline   Reply With Quote
Old 01-11-2012, 11:39 AM   #6
Is it right behind the front stoop?
knucklehead is offline   Reply With Quote
Old 01-11-2012, 02:43 PM   #7
Thanks everyone for their replies...
@Knucklehead...it is right underneath where the front stoop would be located. I'm guessing there is something relevant about that or else you wouldn't have asked. I'd appreciate your thoughts...
Thanks!
Old 01-17-2012, 12:23 PM   #8
I have seen this happen alot when they use stoop brackets on the foundation. It is not allowed around here anymore
Old 01-25-2012, 07:51 AM   #9
I think, there is no need to worry over there. It's so thin actually.
agate is offline   Reply With Quote
How to calculate total glazing allowed in a wall? dalepres Building & Construction 3 04-22-2011 01:28 AM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
Whats best product to fill basement wall crack whatsnewtoday Building & Construction 0 06-14-2010 04:28 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
