Horizontal Disc Sander ??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 03:11 PM   #1
DIY Padawan
CaptainMarvel's Avatar
Question
Anyone know of any plans - or have any ideas - about how to take this homemade disc sander idea, but have the disc sander as the flat surface ... kind of like a motorized lazy susan type deal? (hope I described that clearly enough)
The reason (and goal) for my question is because I like to build my own custom drums (as in musical instrument) and rather than attach a big ole sheet of sandpaper to a table surface (for a kind of truing surface to level out the shell edges), I would love to have a motorized horizontal disc sander onto which I could lower the shells - varying from sizes 8" diameter to 22" diameter - and sand/true them evenly with the circular sanding motion.
make sense?
Thanks for any thoughts, ideas, reference/resources you may be kind enough to share.
TOM
CaptainMarvel is offline   Reply With Quote
The Following User Says Thank You to CaptainMarvel For This Useful Post:
SeniorSitizen (04-21-2015)
Old 03-12-2013, 03:34 PM   #2
Rewards Points: 3,748
How would you control your work piece,best way is with a drum sander,then you have total control.
Canarywood1 is offline   Reply With Quote
Old 03-12-2013, 03:56 PM   #3
DIY Padawan
Well, it's somewhat of a different process than using a drum sander. I've found some reference images and such to help you understand what I am talking about.
This first one is actually a vertical disc sander for the drum shells - so, if one were to go this route, it wouldn't be much of a deviation from the original idea I referenced in my initial post. (I included the caption from the site from which I found the image).
11. Trimming the ends of the drum
The ends of the shell are evened out on a special sanding machine, resulting in a perfectly true drum.
This next [video] example I think best depicts the concept I'm getting at
- you can see the idea at the 0:45 sec point in the video . . .
CLICK HERE TO SEE VIDEO
Any thoughts?
TOM
Old 03-12-2013, 05:20 PM   #4
Yes i see what you mean about the video, but i hate to think what kind of motor you would need to power that sander,as he has to help it start,but i also was suprised to see the control he has with it,probably because he's only using the inner portion of the disc.
Old 03-12-2013, 05:33 PM   #5
DIY Padawan
Well, maybe I'll think of a creative way to accomplish this over the next few months or so.
The good thing about personal hobbies ... there's no rush or deadlines.
TOM
mae-ling (04-21-2015)
Old 04-21-2015, 06:50 PM   #6
Rewards Points: 2
Talking
Horizontal disc sander
Hi...Newbie here but I couldn't help but think of a potters wheel, powered or kick type, to solve your horizontal sander needs. Just a thought. Good Luck
Geaners
Geaners is offline   Reply With Quote
The Following User Says Thank You to Geaners For This Useful Post:
Old 04-21-2015, 07:26 PM   #7
Property Mgt/Maint
Rewards Points: 1,592
what if we keep the standard vertical disc sander but change that flat top to a large v-block. Or maybe 2 rollers to support the drum while you do the edge work
Yodaman is offline   Reply With Quote
Old 04-21-2015, 08:23 PM   #8
You do know this thread is over a year old?????
Old 04-21-2015, 08:32 PM   #9
Property Mgt/Maint
thats funny, maybe captn. will tell us what he is using
Old 04-21-2015, 08:51 PM   #10
Rewards Points: 1,716
I found it useful to send a couple of videos to a young relative drummer for general education purposes.
What the captain is looking for isn't all that much different than a rotary lap.
Warped Brake Rotors - The Cause? DrHicks Automotive Repairs 14 01-20-2013 07:08 PM
Will a Makita disc sander do my jobs? 333Matt Tools 4 05-18-2012 05:53 PM
Ryobi battery powered sander opinion joshgfeller Tools 3 04-30-2012 03:49 PM
Random Orbital Sander Suggestions (<$100) hyunelan2 Tools 11 03-28-2011 07:49 AM
Drum Sander -vs- Disk Sander BlueGuy Flooring 7 08-20-2006 09:44 PM
