Home Electrics Anyone? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 12:32 PM   #1
Home electrics anyone?
Hi, All
Newbie here so hope you don't mind me crashing straight in with a query.
I have an interesting but infuriating and worrying problem.
I am quite conversant with electrics so the task of replacing existing florries with downlights didn't phase me.
I made the circuit up and left the last connection untill I had isolated the power (As you would) I live in a 1960's chalet which has had an extension added and the prev occupant also had a circuit installed to the garage.
I flicked the fuse switch on the downstairs lights and to be safe, the garage AND upstairs lights leaving just the mains live.
Picked up the switched supply 1.5 T&E and cut it to the required length using (Fortunately insulated) wire cutters, and this tripped the fuse box?
Ok, great, I thought. Some dimwit has taken the lighting for this room from the mains.
Completed the connection anyway to check that it'd work and no problems.
Not believing someone could be THAT stupid I decided to check to find out if, throwing the mains switch would extinguish the lights. Nope!
Tried the various fuse switches and the only one that switched the supply to the upstairs lights is the fuse for the upstairs lights.
Now, I THOUGHT I understood electrics but this one has me baffled.
The one thing that I did note was that the T&E used is the old colours but still grey PVC sheathing. It MAY be that someone used the old wiring (DIY).
ANY THOUGHTS?
rizla01 is offline   Reply With Quote
Old 10-23-2010, 03:04 PM   #2
joed's Avatar
Rewards Points: 12,378
Post your location. I think you are from UK. Most of the users on this site are from north America. There are one or two users who are familiar with UK wiring and might be able to assist you.
Old 10-23-2010, 04:56 PM   #3
Hi,
Yes 240v UK I'm afraid.
Forgot to mention that the switch is one of a double switch.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
Home Addition destepan Building & Construction 6 12-05-2007 12:28 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
