Hole In Wall... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 02:31 PM   #1
Hole in wall...
Not sure if this is an easy fix but here it goes. Iím ripping down old wall paper in a bathroom and it appears the sheetrock seam has broken apart making a hole the size of a golf ball. Is there an easy way to fix this without having to take down the whole piece of the of wall?
dcormann is offline   Reply With Quote
Old 03-30-2009, 02:55 PM   #2
Remodeling Contractor
Easy way is to fill hole with expanding foam, let dry overnight. Cut off flush with wall and skim coat drywall compound over it.
Old 03-30-2009, 03:24 PM   #3
Old School
Willie T's Avatar
I'm sure this is much more than you care to hear about, but this gives you an idea of how it usually gets done.
Got a hole in your drywall that needs patching? Remember the unsightly “bump” you left last time you tried this? Well, here’s the way around that embarrassing hassle.
Cut the hole out to a nice, clean square or rectangle.
Screw in a couple of pieces of “backer” wood across the inside of the hole. (1 x 3 works nicely) You just make them about 4” longer than the hole edges, and screw through the drywall to hold them against the inside of the hole. This is what you will screw your patch to. Sink the screws in a little deeper than you normally do for regular drywall faces. And screw within an inch to an inch and a half of the edge of the hole... no farther out.
Cut a square or rectangle piece of drywall 2” bigger (in both directions) than the hole.
Lay the piece face down on a square edged working surface.
Scribe a cut all around the edges, 2-1/8” (heavy) in from the outside. These cuts will each go all the way to the ends of the piece.
Now slide the piece over, past the edge of the work surface so one of the cuts is right over the edge.
Bump the overhang with your hand till it breaks.
Let the broken piece hang over the edge, and starting at one top corner, peel the rock off the face paper... leaving the face paper intact.
Rotate the direction of the piece, and do this same “peeling” technique to the three remaining edges.
Now “dry fit” the patch in the hole and carefully cut the face paper of the wall around the perimeter of the full patch. This means your scribed cut will be 2” bigger than the hole.
Take the patch back out, and peel that 2” strip of face paper off the wall, all the way around the hole. (You may have to use the point of your utility knife a little here.)
Mix some mud a little wetter than usual, and generously cover all the exposed rock around the hole.
Put the patch back in the hole, and hold it in place with a couple of screws.
With a wet sponge, slightly moisten the loose paper edges of the patch... just slightly, you don’t want it soppy.
Now, wipe the paper edges of the patch with a small, wet D/W knife, just like you would real drywall tape, squeezing out all the excess mud from the edges.
Fill the screw holes......... and you’re done with the bed coat. The rest of your finishing comes a little later just like normal drywall work.
What you will find with this technique is that there will be no problems trying to hide the normally taped edges of the patch. The paper edges of the patch imbed into the space where you removed that 2” ring around the hole, leaving a completely flush surface.
FREE "EXTRA" HINT:
You can get a little neater job if you clip off about a half inch, diagonally, from the four corners of the patch paper face before you do your wall scribing. That way, you do not have to contend with any pointy corners that seem to sometimes like to curl up.
FranÁois Duc de La Rochefoucauld
Willie T
Old 03-30-2009, 03:58 PM   #4
RippySkippy's Avatar
I agree with Willie...the last patch I did with this method was virtually invisible... It's an absolutely fantastic method, a little bit more labor...but with great results...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
How To Support A Drywall Patch For Hole In The Wall? dsq Drywall & Plaster 7 02-23-2009 02:48 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 06:40 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
