Hole Taking Forever To Drill - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 03:50 PM   #1
Rewards Points: 264
Hole taking forever to drill
I am trying to drill a 1" hole through 8, thin pieces of steel. I have the pieces mounted to a board, but the hole is taking forever to drill - I stop after a while because of how hot everything gets.
Would it go faster if I drilled a smaller hole, then drilled a second time to widen it?
tibberous is offline   Reply With Quote
Old 08-11-2011, 04:04 PM   #2
Gymschu's Avatar
Rewards Points: 1,022
I would take it to a local Steel Fab shop. They could put it on a drill press and have it done in about a second.
Gymschu is online now   Reply With Quote
Old 08-11-2011, 04:40 PM   #3
Rewards Points: 264
I'm using a drill press. If I knew of one close by I would, but by the time I'd drive it there, I'd be done.
Old 08-11-2011, 04:42 PM   #4
DIY staff
Rewards Points: 7,174
Yes use a starter hole---You may have dulled the big bit--
Are you using a 1" trust drill? Just what are the holes for? Electricians use a knock out punch to make holes--way to expensive for 8 holes.
Or a step drill--which is not to pricey.
Old 08-11-2011, 05:15 PM   #5
Civil Engineer
Rewards Points: 4,938
I had to drill a steel I beam recently for a couple of screws. Pretty simple really, just a couple of tips. First, you need a sharp, hard bit. Tungsten carbide works nicely, titanium nitride is good too. Go slowly, you use low to medium speed on the drill. Keep the point oiled to keep it cool, I use ordinary machine oil. You can certainly start with a small bit and enlarge the hole with a bigger bit, just be careful you don't catch the edges of the large bit on the sides of the hole, you can snap the bit in half pretty easily. I know, there is part of a drill bit somewhere in the room, I can't find it.
Old 08-11-2011, 05:47 PM   #6
jschaben
Rewards Points: 502
If things have been getting hot, the bit is likely toast. Just how thin is "thin". As others have said, good bit, slow speed and lotsa coolant.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 08-11-2011, 06:05 PM   #7
fabrk8r
fabrk8r's Avatar
Are you trying to drill all 8 pieces at one time?
If drill bit was smoking it needs to be resharpened, as stated. It was also good advice to drill holes using a series of bits starting with a small pilot bit and working your way up, increasing by about 1/8" each time. If the material is especially hard, such as stainless steel, it helps to alternate the speed of the drill to help dissipate heat. Use a good cutting oil as well.
The suggestion to have this done at a fabrication, sheet metal or machine shop was good advice. I punch 1" holes through 1/4" plate every day, each hole takes me about 3 seconds using an iron-worker.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-11-2011, 06:09 PM   #8
Rewards Points: 558
Are you using a special bit made for steel? If you use a wood bit, you'll break the tip off the bit. Before you begin any project, make sure the bit is the appropriate material and design for the job. A twist bit is the most common bit, and the tip shape varies according to the material. Harder material needs a larger point angle, and the most common point angle for drilling hardened steel and metal is 150 degrees; most of these are made of high speed steel. Some of the newer twist bits have a negative cutting edge that allows you to drill without the bit walking or a punch to start the hole. Tungsten carbide and titanium tips with a chrome vanadium shanks allow you to drill not only hardened steel but also many other surfaces.
Note whenever you drill hardened steel; make sure that you use a lubricant while you drill to prevent the buildup of excess heat that causes the bit to dull. Also, make sure you drill using a slower drill speed, which also prevents buildup of damaging heat.
epson is offline   Reply With Quote
Old 08-11-2011, 06:36 PM   #9
Rewards Points: 264
Im thinking the bit is just garbage - I tried sharpening it with a dremel to no effect. I drilled a half inch hole super easy.
This bit is black oxide I believe, but I've used it alot before, on steel. It's the only bit I have bigger than a half-inch, so it's the one I use whenever I need a big hole in non-wood. Bits this size are like $20 a piece - sucks to have to buy a new one.
Old 08-11-2011, 06:44 PM   #10
Rewards Points: 5,336
You would drill through the steel more expediantly if you had sharp bits and maybe oil to cool the process.
Ron
B. Franklin 1759
Old 08-11-2011, 06:59 PM   #11
Rewards Points: 558
Well a dremel wonít cut it. You would either need a drill sharpener like the drill doctor to get the right angle or just buy yourself a new bit. Now if it is black oxide itís not a bad bit. Most common bits you usually buy are twist drill bits in a standard length called jobber lengths, with the length varying according to the bit diameter. These will handle most of the jobs you tackle and are usually black oxide. If anything, donít buy cheap bits. Theyíre frustrating and can be dangerous, causing you to push or exert more force than needed when drilling.
Old 08-11-2011, 07:44 PM   #12
jschaben
Rewards Points: 502
I agree with the Drill Doctor, one of the best maintenance investments I've made. Largest bit the usual consumer version handles is 3/4" though.
John Schaben
Old 08-11-2011, 08:06 PM   #13
Rewards Points: 558
then you got to take it to a guy like this:
or try and sharpen it yourself with a file or if you have a bench grinder..
Old 08-11-2011, 10:17 PM   #14
Being a retired Tool&Die Maker- I would suggest a "hole saw"--slowest speed possible with gradual down force and use cooling oil.
Giles is offline   Reply With Quote
Old 08-11-2011, 10:31 PM   #15
Concrete & Masonry
Rewards Points: 636
I'll bet you don't rely on a Drill Dr. either.
We've done a lot of work in a T&D shop through the last 10 years, and I'm always amazed at how quickly and accurately you guys can sharpen a bit by hand on a bench grinder.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
oh'mike (08-12-2011)
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Drill: What type to buy? Hurriken Tools 13 09-07-2010 04:00 PM
taking out wood stove how to fill hole. bowanna03 General DIY Discussions 6 06-16-2009 09:46 PM
Best (easiest) way to drill into poured concrete wall Todd-sta Building & Construction 11 11-16-2008 03:57 PM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
