Hole In Foundation?!! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-11-2013, 08:21 PM   #1
Hole in foundation?!!
Hi,
I have had a leak under foundation and plumbers tunneled under the house. In the process I discovered that I can see bottom of bathtub from under the tunnel. This is nor normal?
strobes is offline   Reply With Quote
Old 10-11-2013, 08:47 PM   #2
MarginallyQualified
Rewards Points: 2,464
Slab on grade?
If you had a regular house you'll often see hoes that large under tubs too. Less of an excuse for it there but it still happens.
Old 10-11-2013, 09:37 PM   #3
yes, slab on grade. I'm in Texas and is it critical to fix this hole? I'm thinking about termites.
Also how close I need to watch plumbers when they fill up the tunnel? Can voids cause foundation problems?
Best way to fill big hole in foundation noquacks Concrete, Stone & Masonry 32 03-01-2013 02:32 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Small Foundation Hole? jage Building & Construction 1 11-06-2009 02:24 PM
Where to locate a large rectangular hole in cinder block foundation benjamincall Building & Construction 0 10-30-2009 02:11 PM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 08:08 AM
