Hole In Basement Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 09:31 PM   #1
Hole in Basement floor
I'm buying a new construction house with an unfinished basesment. I noticed that there is a framed in square in the basement floor, approximately 12 inches square, around which they poured the floor. The square is only filled with loose gravel. I think it's in the area that would normally be the lower floor bathroom.
What os the purpose of this square?
wileefox is offline   Reply With Quote
Old 05-19-2011, 09:33 PM   #2
Framing Contractor
Rewards Points: 78
To tie in the drains.
sixeightten is online now   Reply With Quote
Old 05-19-2011, 09:44 PM   #3
hole in basement floor
Please elaborate. I don't know what that means. Is there a stub of pipe somewhere beneath the gravel? If so, did they cap it? And if so, do I dig down around it and cut the cap off?
Sorry for all the questions, but no experience with this kind of thing
Old 05-19-2011, 09:53 PM   #4
Framing Contractor
Rewards Points: 78
This was going to be a tub/shower location. There will be a 2 inch drain under the gravel. Depending on the type/brand of unit, the center line of the drain can vary. Is there also a toilet flange already set?
Old 05-19-2011, 10:00 PM   #5
There is a stub of pipe sticking out of the floor about an 1/8 or 1/4" high but no flange. I'm sure the plans must call for a flange to connect to that stub.
How do they keep any of the gravel from entering that drain pipe?
Interesting thing is that there are two drain pipes running down from the main floor bathrooms, but neither of them was plumbed with a Y for the downstairs bathroom sink.
Old 05-19-2011, 10:01 PM   #6
Framing Contractor
Rewards Points: 78
The end of the pipe will have a temporary cap on it.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Basement Sink Runs to Hole in floor?!?!? coderguy Plumbing 3 04-03-2011 10:26 PM
Adding a basement floor drain for A/C Condensor SuzieSawzall Plumbing 9 03-28-2011 08:51 AM
Concrete Basement Floor Insulating options McSweny1103 Insulation 7 03-08-2011 06:24 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
