Hole Above Heating Unit - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 09:28 AM   #1
Angry
Hole above Heating Unit
We purchased a home not lone ago and the gas heating unit is in a semi type hall closet. The closet is about 2 1/2 feet wide and 4 1/2 feet long. Looking up, I see silver ductwork running in several directions and then I see the roof of the house. Is this normal? This "closet" has no ceiling, just the roof ! Advice needed.
lckennedy303 is offline   Reply With Quote
Old 06-10-2009, 11:14 AM   #2
It could that way to allow fresh combustion air for the furnace.
corriewolfe is offline   Reply With Quote
Old 06-10-2009, 12:31 PM   #3
Household Handyman
Rewards Points: 1,408
I can't give you the exact correct answer on this, but these units are very common in my area and they are all that way, with the opening at the top. Maybe it does have something to do with ventilation for combustion IF you have gas heat. However, I do know this, my Mom's house had an infiltration of honey bees a few years ago in the attic. These bees made their way into this HVAC closet and through the cracks of the door to the closet into the house. Quite a scare for her! After we got rid of the bee problem I placed screen wire over the opening so there could be ventilation but keep the buggies out. My two cents worth, David.
Old 06-10-2009, 12:59 PM   #4
Good idea. We do have a lot of bats in this area.
Old 06-11-2009, 07:54 AM   #5
Registered User
Termite's Avatar
I'd almost guarantee that they're combustion air vents, and they are needed/required. The screen wire idea is a good one! If the furnace is in a hallway and not in a closet that opens via a bedroom, another option is to install a fully louvered door.
Tags
hole in ceiling , no insulation
Loud intermittent Metallic sound from Heating Unit uy7473 HVAC 2 01-21-2009 04:15 PM
Most efficient heating unit farooq Plumbing 1 08-02-2008 04:19 PM
Heating Unit farooq Plumbing 2 07-18-2008 05:23 PM
AC or heating unit just will not come on lilda12 HVAC 4 06-16-2008 06:44 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
