Hi-pitch Ringing Tone - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 09:58 AM   #1
hi-pitch ringing tone
I am getting a hi-pitch ringing tone that goes in and out behind my bedroom wall (almost like a vegas slot machine -- a fading ding ding ding).
Strange thing too is at that it will literally stop for 3-4 days and then come back on all night, going in an out - a fading ding ding ding.
While it was making the noise:
-- I shut off main electricty panel to house, still ringing
-- shut of main water and opened a faucet to drain thinking air, still ringing
-- turned on main sprinkler system, still ringing; as there is a drip system on opposite wall in flower planter outside and i do hear loud shut off valve noise behind wall when they switch to other water areas, I guess
Any other thoughts/suggestions?
Cohiba is offline   Reply With Quote
Old 05-06-2011, 10:07 AM   #2
Dont mean to sound like an a$$ but is it something from outside the house? ie. neighbours?
ahrens is offline   Reply With Quote
Old 05-06-2011, 10:11 AM   #3
I checked outside, nothing -- and it only come from behind that one wall. Just havinf troube determining if it is something electrical or plumbing. I shut off all electrical, so think it has to be plumbing -- water pressure, air, something??
Old 05-06-2011, 10:23 AM   #4
Old School
Willie T's Avatar
Did you look for a cell phone lying in the grass outside?
Willie T
Old 05-06-2011, 10:24 AM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Is there a plumbing vent that passes in that wall? A shot in the dark but maybe it's something to do with that somehow? Or maybe a sound in the sewer system that is resonating through that pipe?
Old 05-06-2011, 10:33 AM   #6
no cell phone, plus this has been going on for months, so anything battery operated would have discharged log ago
Old 05-06-2011, 11:25 AM   #7
i will ask plumber, i wish i could figure this out, now its silent again...very frustrating.
Old 05-06-2011, 11:30 AM   #8
the Musigician
DangerMouse's Avatar
If you could record it next time you hear it, it might help us identify it.
DM
Old 05-06-2011, 11:35 AM   #9
i tried but it is too hi pitch, any another suggestions?
considering i shut off electric main switch, it must be plumbing yes?
would an old telephone line in house make this sound?, as i do not use -- i use cable phone instead.
Old 05-06-2011, 11:38 AM   #10
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
unless others hear this, you should probably speak with a doctor.
Old 05-06-2011, 11:44 AM   #11
good one, but my wife hears it too, so not what you think. again, hi-pitch dinging sound that fades in and out. seems to occur mostly at night/early morning when in bed.
Old 05-06-2011, 11:50 AM   #12
nap
You talking to me?
nap's Avatar
I wasn't joking. Obviously since you are not the only one to hear it, it;s not an issue but there are plenty of medical problems that can cause a person to "hear" odd sounds.
anyway; is your house attached to any other buildings? What type of businesses are in the area? How close is the closest building to your home?
Old 05-06-2011, 11:54 AM   #13
i agree, definitley not a hearing issue.
i am in a all house residential area -- so no common walls. the bedroom wall where i hear the sound has the backyard behind. i can hear plubming valves tun on an off wehn sprinkler run, bit not the same sound as the hi pitch dinging.
Old 05-06-2011, 12:16 PM   #14
nap
You talking to me?
nap's Avatar
do you or anybody in your neighborhood have a wind chime?
Old 05-06-2011, 12:21 PM   #15
no wind chime. again, you can hear it coming from the wall when you listen closely when everythig is silent, and the other side of the wall is a large backyard. the only thing on the other side of wall is plastic drip water lines for plants, which only comes on in the morning -- timer controlled, which is in garage far away from bedroom.
I know, strange!
Replacement Condensor Fan blade pitch? daviesow HVAC 13 05-11-2015 09:17 PM
Roofing MINIMUM pitch? ControlTech Roofing/Siding 1 11-26-2009 09:10 AM
best for low pitch roofs tomseeley Roofing/Siding 3 06-09-2009 09:54 AM
Building Roof over Roof, changing pitch Thomas O Roofing/Siding 7 03-05-2008 09:51 PM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing/Siding 3 03-27-2007 12:16 AM
