Help W/ Plaster Wall Repair - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 02:59 PM   #1
Help w/ plaster wall repair
I have a house from 1944. Redoing the kitchen and pulled off formica backsplash to reveal thick dark brown adhesive. Used a power scraper to get the heavy thick stuff off. Now I'm left with the rest. I very uneven. It's not water soluable. It doesn't react to a heat gun, and today I was attempting to sand the hell out of it. No dice. Help!!
rfk66 is offline   Reply With Quote
Old 02-27-2011, 05:46 PM   #2
What are you planning on having for a final finish?
That stuff is nasty, I've seen grown men weep out of frustration trying to remove it.
It's easier to take out the plaster board down to the studs and re-blend in new blue board and plaster.
(I've seen contractors do just this)
You'll have to chisel, then resurface if you want to paint.
The easiest way out is to cover it over with new tile.
Do It Right is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Using Schluter-KERDI wall system over plaster walls. ADIAGA Tiling, ceramics, marble 6 08-02-2010 09:56 PM
Plaster over Concrete Sheet Wall? bk412 Drywall & Plaster 1 06-17-2010 10:10 PM
Need to fix old plaster on brick wall - any hints? Leah Frances Building & Construction 1 01-14-2010 06:55 AM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 03:13 PM
