Help W/ Gap Fill (pic) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 03:05 PM   #1
Help w/ gap fill (pic)
Any ideas for a quick-fix?
http://www.atlasgroupga.com/column%20orig.jpg
keatz85 is offline   Reply With Quote
Old 05-13-2012, 04:10 PM   #2
kwikfishron's Avatar
Rewards Points: 86
I’d dig out and clean up all the garbage between the siding and the rock then cut a piece of 2x3 Cedar to fit in-between the siding and rock, scribing in and cutting the Cedar on the rock side to get a close fit, caulk both sides with a polyurethane based caulk and paint to match.
kwikfishron is offline   Reply With Quote
Old 05-13-2012, 04:41 PM   #3
Rewards Points: 12,808
If your going to do home repairs right your going to have to get past the quick, cheap fix thing, unless you like doing it again.
I personaly would use 1 X 4 vinyl instead, it will never rot, need sealing, transfure moisture.
Old 05-13-2012, 06:19 PM   #4
A Little Of Everything
Rewards Points: 1,356
Originally Posted by keatz85 View Post
The quickest fix (not necessarily the best) is going to be to get ALL the old caulking/sealant/crap out of there, the fill it with a GOOD quality exterior paintable caulk.
DrHicks is offline   Reply With Quote
Old 05-13-2012, 06:20 PM   #5
So you would just tear off all of the (what appears to be cedar) siding, and replace it with vinyl, as a solution to this problem?
Old 05-13-2012, 09:33 PM   #6
Originally Posted by kwikfishron View Post
Id dig out and clean up all the garbage between the siding and the rock then cut a piece of 2x3 Cedar to fit in-between the siding and rock, scribing in and cutting the Cedar on the rock side to get a close fit, caulk both sides with a polyurethane based caulk and paint to match.
That's what I was thinking, thanks for verifying. The only thing else that came to mind was maybe a big gap foam sealant but that probably wouldn't look too good.
Old 05-13-2012, 09:35 PM   #7
You can fill a 1" gap w/ caulk?
Old 05-13-2012, 09:41 PM   #8
No not the siding, just replace the trash that was used to fill the gap from the siding to stone with vinyl lumber.
Old 05-13-2012, 10:35 PM   #9
+1. Something like a piece of Azek is perfect for this spot. Paintable, and will be there longer than the stone wall.
pucks101 is offline   Reply With Quote
Old 05-14-2012, 08:42 AM   #10
Rewards Points: 1,426
Spray foam breaks down in the sun.
mikegp is offline   Reply With Quote
Old 05-14-2012, 04:54 PM   #11
Davejss's Avatar
Rewards Points: 740
Scribe a piece of Azek (or other weather resistant trim board) with a compass\scribe. Follow the scribe line with a jig saw or coping saw. Fine tune the cut with a rasp. Install it, caulk it and paint it if desired.
Davejss is offline   Reply With Quote
toilet takes to long to fill lonewolf22 Plumbing 5 11-30-2011 08:03 AM
To fill, or not to fill? IRuehl Landscaping & Lawn Care 7 08-27-2011 05:30 PM
Leaking Fill valve tallman Plumbing 1 07-14-2011 02:01 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 09:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 07:19 AM
