Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-27-2009, 11:16 PM   #16
Help w/boring under a driveway....
20/20 advice installing pipe under driveways with out washing them out cutting them out or bidding it out, check out www.bulletmole.com watch the video it's simple, clean & dry
p.s. dose anyone no what time it is ?
tomthumb2009 is offline   Reply With Quote
Old 01-28-2009, 01:00 AM   #17
get 4in fitting and some short pips and a small fitting awater hose would fit on .
cut teeth in the fitting and wate bore with a chain wrench add pipe as you go
woodtwister is offline   Reply With Quote
Old 11-05-2009, 10:42 PM   #18
BobRobert,
I know this is an old thread but i'm curious how you solved your problem? I just bored under 3 sidewalks (8' wide) in North Carolina. The soil there is hard, red clay like in Georgia. It was terrible. We finally beat a 4" pvc pipe through and used a zero degree fitting on a pressure washer to clean out the pipe as we went along. At one point the pipe hit an obstruction so we pulled it out and used the pressure washer alone to shoot a hole under the sidewalk. Then we were able to easliy force the pvc pipe through.
PS: Love this forum! Been a lurker for some time.
JackTrade is offline   Reply With Quote
Old 11-05-2009, 10:47 PM   #19
Xtreme DIY'r
BobRobert has not been back to this site since Nov 2008, about a year ago
Old 11-06-2009, 05:52 AM   #20
I went under a city street once to run a new water line to a house - probably 20-25' wide street. City would not allow the street to be cut/patched. Made up a water drill of pipe. Used a jack hammer to drive the water drill pipe, adding pipe sections as we went along. Was a heck of a lot of work, but got it done. Your run is not as long - I would think very doable with a water drill.
sloped driveway at 1 family house lk5333 General Discussion 2 02-20-2008 07:37 AM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 12:02 PM
Driveway Pitch handy man88 Building & Construction 6 09-11-2007 06:15 PM
