Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-04-2008, 07:19 PM   #1
Bobrobert's Avatar
Default Help w/boring under a driveway....
I need to put a 4 inch conduit under my driveway to re-route a sump pump discharge. Lacking a boring machine, "directional or other wise," what are some of the options for getting a "4 inch" hole poked under the drive. I'm going to go a bit diagonal so the bore would be no more than 10 feet, probably less.
I'm assuming that there are no rocks under the gravel bed for the driveway. A water hose on a 1 inch ridged pipe would probably get a small hole through there, but I need room for a 4 inch PVC. What are some of the methods that you folks have used, or is this definitely a boring machine job? I guess I could cut the driveway but wanted to avoid that if I could.
It's pretty much level, a little down hill, so will have to dig a receiving pit, but I'll have about 15 feet of straight trench to dig getting to the drive that would allow me to lay out flat any length of pipe needed to get under the drive.
Thanks in advance for any help or suggestions.
Bob
Bob .....[SIGPIC][/SIGPIC] ...You "can't" work all the time!
Bobrobert is offline   Reply With Quote
Old 03-04-2008, 10:54 PM   #2
Default Clarification needed
I have a sump pump also and it pumps out in a 1/12" line or 2" at very tops. Do you REALLY need that 4" to drain it?? Second question, where is it going to?? Storm sewer? or ditch?
If I were to do this my 'preferred' pipe would be heavy wall pvc 3"(or smaller)."IF" your talking 4" thin wall drain pipe,,,I wouldnt use it,,,weight of dirt OR stepping on it will crush and break it!!
justdon is offline   Reply With Quote
Old 03-04-2008, 11:52 PM   #3
Bobrobert's Avatar
Thumbs up Valid point....
Justdon - Thanks - probably should have explained a bit better.
My sump discharge comes out of the front of my house below ground with a 1-1/2 inch line, and then dumps directly into my "underground" down spout drain system (thus the 4 inch line) and the down spout line runs over to the side of the house before it comes up to ground level.
It's a combo of both the sump pump discharge and the down spout drain system that I need to get to the other side of the driveway. I was planning on using the thickest wall PVC I can buy just for the part under the drive. I can also put in steel if necessary, but would like to use the PVC for ease and expense.
But you have given me food for thought. You've made me think about taking the sump line out of the down spout drainage system and extending that line only over to and under the driveway. It would be much easier to poke a 1-1/2 line under the drive than a 4 inch, that's for sure. I can live with what water comes out of "just" the downspouts, it's the sump that dumps water for 3 or 4 days after a hard rain, and it all runs into the drive at the front of the garage doors.
I may just do that very thing. Do you know if there is any problem or concern with running a 1-1/2 diameter discharge line for 60 or 70 feet before it can dump? Would there be any pressure issues? It would be all sloped down a bit, no up hill at all. Hey - I could also up it to a 2 inch line outside the house if there were pressure concerns.
All right!!! THANK YOU! I think that's exactly what I'm going to do. Up it to a 2 inch line outside the house and run that over and under the drive.
Do you see any potential problems with that?
That should work OK right?
Bob
Old 03-04-2008, 11:55 PM   #4
Bobrobert's Avatar
Default Missed part of your question...
Justdon -
Sorry - I didn't answer where the line would dump. It would just come above ground on the other side of the drive on my property and run onto the lawn, down hill and out into a field.
Bob
Old 03-05-2008, 11:02 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
There are companies that have specialized equipment for such. Can't quote you prices, but I know it's not cheap. They bore a rod thru with a small chain or other, and then use that to pull boring/drilling thu to the other side.
I do not know if rental companies carry such equipment.
We had an industrial client (company) that needed data lines run from one building to a new building in the same office park. They called up, but before we could look into it more, they located a company that did it. I think, they may have paid $1500.00, for the one area that was bored out? Often, such work has a minimum cost, then a LF rate....
- Build Well -
Old 03-05-2008, 12:30 PM   #6
Professional Handyman
End Grain's Avatar
I had to run landscape wire underneath a circular concrete driveway that was about 10' across. I dug down on both sides of the driveway to create troughs right at the edge that were about 16" deep, 2' wide and 5' in length alongside the driveway. Then, with two long lengths of 3/4" PVC pipe, a PVC garden hose fitting, a PVC coupler and a plastic "water drilling" or sweeper nozzle, used simple garden hose water pressure to make a channel under and across it. The 16" depth was necessary to get the PVC rig as close to the ground as possible and therefore keep it fairly level as I fed it through. The PVC bends so once it gets started, you can keep it from dipping and drilling downward. The troughs are necessary so that dirt and water have a place to go as the water is boring the hole. All-in-all, the hole I made was about 3" in diameter by the time I got it fully across. So, if this is something you think might work in your case, you could pull the rig back and forth with the water running to open the hole up more. If there are large rocks or solid debris buried under the driveway where you start, you may have to try "water drilling" in a different spot. This method does make lots of mud and you may have to dig up some of it and pile it up as you go but it's one way used out here in AZ to get something under a concrete slab.
Don't force it. Use a bigger hammer.
End Grain is offline   Reply With Quote
Old 03-05-2008, 12:44 PM   #7
Master General ReEngineer
Ayuh,...
I know it's not what you want to hear,...
But,...
Cutting,+ trenching your driveway will probably be the Cheapest,+ easiest way to go....
Old 03-05-2008, 02:42 PM   #8
pressure washer?
ponch37300 is offline   Reply With Quote
Old 03-05-2008, 03:36 PM   #9
I've never used one but this might work:
http://www.borzit.com/customhtml/
Old 03-05-2008, 08:50 PM   #10
nap
You talking to me?
nap's Avatar
10 feet or less? just dig yourself a tunnel if it comes to that. 10' isn't that much to dig under something.
Other than that, you can use a combnination of a couple things;
water drilling is probably your best bet though. If you use a spray nozzle that angles, you can rotate it and drill a larger hole.You can also use this driling rig and place it inside the 4" pipe. A sledge hammer will help it along. Use wood blocks to prevent damaging the pipe
nap is online now   Reply With Quote
Old 03-06-2008, 10:25 PM   #11
Bobrobert's Avatar
Thumbs up Is pressure buildup a concern........
Hey guys - Thanks for all the great input. I appreciate it much. This is one of the best sites for straight forward information, I have ever come across. We're getting some warm days here in central KY and will be starting the "big dig" under the drive soon.
I just measured my discharge and it's 2 inch OD. Does anyone see a problem with running this size line about 60 to 70 feet before it discharges into open space, or should I up it to a 3 inch OD at some point. I have a 1-1/2 hp pump and was wondering about pressure built up.
Again thanks for all the replies....Bob
Old 03-07-2008, 09:28 AM   #12
I imagine your pump manufacturer can tell you how high and how far it will pump through a 2" pipe. Check their documentation and if you don't find the info give them a call.
Old 03-07-2008, 10:49 PM   #13
One problem with boring under a driveway is not being able to recompact the soil underneath and then the driveway buckles and collapses along the route of the pipe. The end result can be a patch that looks worse than cutting the driveway and trenching for the pipe installation.
Old 03-07-2008, 11:46 PM   #14
Bobrobert's Avatar
Jogr - Good point & I'll give them a call. Thanks
AllenJ - I thought about that as well and it's a concern I've had. I thought if I could go with a 2 inch OD that I would try to water bore it and put it as far down in the ground as possible under the drive. If I see that it's starting to sag I'll cut the drive at that point and compact it dirt and patch the drive. But that would mean a much bigger cut than a 2 or 3 inch if I did the cut on the front end wouldn't it? Hmmmmm! I just I'll have to ponder that one for awhile..... Thanks...Bob
Old 03-09-2008, 08:54 PM   #15
I forgot to mention that any driveway sagging or buckling will not happen right away. It may be weeks or months later, after the affected area has been driven over a lot.
More On This Topic
Paintball sport fans often build elaborate defensive positions for both indoor and outdoor facilities. One good defensive position to build for outdoor paintball fields is a standard U.S. Army-style foxhole. Read More »
How to Survey a House
How to Survey a House by Expert Village
Hi, I'm John Jackson from Remax Suburban in St. Louis, Missouri. I'm here today to talk about how to buy a house for Expert Village. With the property under contract, the lender now requires us to do a survey of the property. I'm going to talk to you a... Read More »
Hi. I'm Albert Hedgepeth with Expert Village. Today we are going to talk a little bit about boat maintenance. What we are going to talk about now is a macerator. A maceration system is used to chop up sewage that is on your boat and the discharge from... Read More »
Hi I'm Susan Ting on behalf of the Expert Village I will be here to show you how to make a teapot. The next step is to attach the spout and you score this again follow the line of your spout. You want to make sure this is a good attachment and also score... Read More »
Hi my name is Elliott Kwong on behalf of Expert Village. Today I'm going to teach you how to make a kaleidoscope. Okay so we are going to want to cut our pvc pipe. Here we have a pvc pipe and remember it is about 1.5 inches in diameter. So let's measure... Read More »
sloped driveway at 1 family house lk5333 General Discussion 2 02-20-2008 08:37 AM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 01:02 PM
Driveway Pitch handy man88 Building & Construction 6 09-11-2007 07:15 PM
Driveway discoloration after water seal. DoubleD General Discussion 0 03-11-2007 07:27 PM
Driveway repair job. Aredex??? rcruz24 Building & Construction 0 07-11-2006 10:02 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
