Help!! Removing Sliding Doors? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-07-2006, 07:44 PM   #1
Help!! Removing sliding doors?
I am parking a car in my basement tommorrow. I need to figure out how to get the sliding glass door off and the other glass panes. How do you do this? I would like to leave the frame in tact, but just remove the inside stuff. I'll ramp the car over the frame so that it doesn't damage it. I have Simonton vinyl windows in the basement. Any help would be greatly appreciated. I noticed two holes near the bottom of the door, does this remove the door from the track? Thanks! -Mike
luo2000 is offline   Reply With Quote
Old 04-07-2006, 08:06 PM   #2
Are you sure you can make a ramp that won't damage the threshold, that is a bit of weight...
bob the builder is offline   Reply With Quote
Old 04-07-2006, 08:13 PM   #3
Two car ramps
I was thinking of just buying two sets of drive up car ramps and putting them back to back. I could always use lumber ramped up to a cinder block and then bridged by lumber or steel. I think the ramps should work though. Its a pretty light weight car < 2000 lbs.
Old 04-07-2006, 08:16 PM   #4
So far I have screws undone near where the door closes. I read that you are supposed to pull two panels off at the lower section of the door on the outside. I see a panel on top and on the bottom for each glass pane, but I chipped the corner when trying to pull it out. Is this what I should remove?
Old 04-07-2006, 08:32 PM   #5
okay looks like i use the two holes near the bottom of the door to adjust the roller heights, which allows me to remove the door. So last remaining is to figure out how to get the fixed panes of glass out. My doors look pretty similar to this:
http://www.hammerzone.com/archives/d...1/slider1.html
Going to check for some screws hidden under trim on the inside now...
Old 04-07-2006, 08:50 PM   #6
alright two pieces of trim off from top and bottom tracks on outside of door. now what? isn't this board supposed to offer help? cause all i got is a guy saying it was too much weight for the threshold...
Old 04-07-2006, 09:23 PM   #7
I think bob the builder ruined it for me. By providing me with information that didn't contribute to finding a solution to getting the doors off. And now everyone thinks my question has been answered because of the responses. Thanks bob, for the comment and then disappearing on me!
Old 04-07-2006, 09:27 PM   #8
I've got a solution to the weight problem bob, you can lye down inbetween the ramps and then i will drive over them. You protect the threshold. He he jk. Well that's taking it a bit far... but can anyone help me?
Old 04-07-2006, 09:43 PM   #9
I Am So Screwed
Old 04-08-2006, 02:34 AM   #10
DIY has taken on a new meaning... Do*it*yourself with no help.
Old 04-08-2006, 02:13 PM   #11
Old 04-10-2006, 11:10 AM   #12
Construction Junkie
I just want to come and watch....I've never seen a door frame collapse before......
seriously, maybe the reason there's no answer is because there's no answer. In the course of many years of dedicated diy'ing, I've put a lot of things where they didn't belong, but this just sounds like a disaster. Let us know how it turns out.
sharisavage is offline   Reply With Quote
non pocket sliding doors? jamesdart Remodeling 3 03-07-2009 04:48 PM
sliding interior doors? jamesdart Roofing/Siding 4 02-06-2007 09:15 PM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 12:43 AM
Sliding Glass Doors Drewimus General DIY Discussions 2 10-02-2006 09:06 PM
removing frame to sliding glass door luo2000 General DIY Discussions 1 04-09-2006 08:00 PM
