Help With Plastic Mealter & Vacuum Sealer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-31-2015, 02:34 PM   #1
Rewards Points: 8
help with plastic mealter & vacuum sealer
I need help, I wanted to make a plastic vacuum mealter and sealer. For the part to melt the plastic I wanted to use heating rods, of some sort, rather than the electric skillet version I saw online. I need help with the electrical can anyone tell me what I would need.
keycloudarmory is offline   Reply With Quote
Old 08-31-2015, 02:43 PM   #2
Mad Scientist
Nichrome wire with a reflector behind it. Start with a Google search for "hot wire bender", the heating element design should be about what you're looking for, assuming I've interpreted your vague intentions correctly. If you've got a grasp of electronics, it's fairly simple.
If you don't, you'll want to find someone local to give you a hand. Got a hackerspace somewhere near you? https://wiki.hackerspaces.org/List_of_Hacker_Spaces
If you're lucky enough to have one nearby, you can probably find some people to help you out.
McSteve is offline   Reply With Quote
Old 09-01-2015, 02:19 PM   #3
Rewards Points: 8
so my plans were to have heat on one side that melts the plastic then i lift the plastic slam it onto the thing i want to mold and turn on the vacuum sealer part and it causes the plastic to make the shape the main problem is the build i saw was using a electric skillet that plugs into the wall. I wanted to use heating coils since my build will be roughly the size of a folding table.
Old 09-01-2015, 02:31 PM   #4
Mad Scientist
Sounds kinda like you're talking about a DIY vacuum former, unless I misunderstand. My hackerspace has two commercial vacuum formers, about 24"x24" and maybe 24"x36". Both use something that seems to pretty much be an electric oven heating element. I don't know if you need that much heat, depends on your choice of plastic and its thickness.
Have you looked other DIY vacuum formers besides the one with the skillet?
Old 09-01-2015, 02:41 PM   #5
Rewards Points: 8
Old 09-01-2015, 02:43 PM   #6
Rewards Points: 8
I did i saw this one and I liked it cause I was going to mod it to fold when not in use so that way our workspace is not cluttered with tools we don't use all the time. but i wanted it to fold out and be able to plug in when in use and be good to go on a large scale.
Old 09-01-2015, 03:01 PM   #7
Mad Scientist
I guess if I were building this, I'd probably grab some heating elements out of a space heater or something, find a way to safely mount them to a noncombustible reflector like a cookie sheet, baking dish, or custom-fabricated metal pan if you want to get fancy.
Feed them power through a variac to control the heat and limit the current. Just a few good sized space heater elements will trip a breaker if you feed them 120V from a standard 15 or 20A circuit without limiting the current somehow.
That's about the extent of my knowledge, I'm afraid. Be safe.
Concrete Sealer For Home Patio & Sidewalk JasonCA Concrete, Stone & Masonry 1 01-22-2013 03:28 AM
correct stain and sealer for wooden front door GLS0628 Windows and Doors 2 08-06-2012 11:02 AM
correct stain and sealer for wooden front door GLS0628 Painting 1 05-14-2012 10:10 AM
Redgard vs 6mil Plastic Sheeting for tiling amodoko Remodeling 0 01-18-2012 12:57 AM
Do I need two layers of grout sealer? sukhenkoi Kitchen & Bath Remodeling 5 01-14-2012 07:53 AM
