Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-23-2007, 06:54 PM   #1
Default help! my walls are troubled
So I'm getting my house ready to sell and I realized that I had to take the
paneling down in the master berdroom because people seem to hate paneling these days. took it down and I am left with a NIGHTMARE!!! 2 of the walls have about 4 layers of wallpaper and paint and when I tried to scrape it, I realized that the drywall underneath all those layers was never primered-so it just tore the paper right off the drywall and left holes. the other walls were also not primered. the wallpaper on these walls just came off in full sheets leaving on the fuzzy backing which is impossible to remove because those walls were never primered. tried the DIY stuff and It did not help. any advice? this room is Huge 27- feet long, nothing but walls!!! i would hate to put sheet rock over it because it would be too much work and I think it would make the room even hotter than it has been-even in the winter months with the vent blocked. I am lost and need some ideas. anybody please.
donnamarie is offline   Reply With Quote
Old 08-23-2007, 07:12 PM   #2
Sounds like you need the walls skim coated, but it's just a guess. If you don't know a skim coat is a thin, smooth, layer of drywall mud. It might be worth calling in a professional for an opinion at least.
Concordseeker is offline   Reply With Quote
Old 08-23-2007, 08:48 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
This one's easy
Well, easy to answer anyway
Remove any loose hanging wallpaper
Prime the room with Zinsser's Gardz
It was invented for this type of project
It will sink into any loose stuff, and the fuzzy paper left over, and turn it hard
Hard enough to scrape off any lumpy chunks left over, cut off any floppy paper w/o ripping more off the walls, and allow you to skim coat w/o the whole she-bang falling down
After the Gardz goes up, scrape or sand if/where needed
Then apply joint compound (skim coat) with a large "taping" or joint compound knives to smooth out the transitions, bumps, holes, cover the fuzzyness, etc....
It may take a few coats and some sanding
If you get a smooth wall, dust it well, and prime (regular primer is fine, but Gardz will work too if you have any leftover)
Then you can paint
slickshift is offline   Reply With Quote
Old 08-29-2007, 11:49 AM   #4
DON"T start removing any of it unless you want to take on a big time consuming project.
Some wallpaper is very hard to remove + you're under the mercy to the drywall holding up well after the removal..
It will be a wet gooey mess trying to take it off and there is a strong possibility that in order to get off all the wallpaper you have to scrape hard and gouge the dry wall even w/ the proper chemicals to lossen it.
whatever the case maybe you'll be doing a lot of sanding..and even after that you'll be doing some mudd and likely drywall repair ..not to mention you'll prolly have exposed nails pushed through the drywall from when the temperature change when nailed in the studs..
Even if you skim it, it might not look good..depending on overall condition of the drywall
tough call on what to do....It depends on how bad things are...Just pray it comes off easily..even if it costs money to rent a heat steamer it might be worth it to save both time and more $$$ later on
gogogodzilla is offline   Reply With Quote
Old 08-29-2007, 12:11 PM   #5
Darylh's Avatar
Originally Posted by slickshift View Post
This one's easy
Then you can paint
I am second in favor of the above other than redrywalling..
www.geocities.com/edimprovement
Darylh is offline   Reply With Quote
Old 08-29-2007, 02:08 PM   #6
Weekend Builder
Crackers's Avatar
Drywall. Fast and easy. Looks like a new room. Prime and paint a neutral beige.
Crackers is offline   Reply With Quote
More On This Topic
What Is Drywall?
What Is Drywall? by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be answering the question what is drywall. Drywall is a construction product that is commonly used to finish the interiors of buildings. Since it was invented, it revolutionized the... Read More »
How Much Drywall Do I Need?
How Much Drywall Do I Need? by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about calculating materials for drywall. Each sheet of drywall is 4 feet, so I am going to go ahead and measure the length of my wall. The measurement of my wall is 23... Read More »
We're back in our room and now we've got, mostly finished, drywall and a coat of primer paint and we chose this orange primer color because we're going to come over it with a caramel color. Drywall, mud, tape, sanding and a coat of primer always over... Read More »
Taking the time to properly prepare your walls for papering will be well worth it in the long run. New wallpaper will add a fresh look to any room and will last for many years to come if the walls were prepared before the wallpaper ever goes up. So... Read More »
How to Cut Drywall
How to Cut Drywall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you how to cut drywall. The first thing that we need to do is measure the height of our wall so that we know how long to cut our sheet of drywall. This wall is about 89... Read More »
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 05:07 PM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 17 07-25-2008 06:59 PM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 08:55 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 07:33 PM
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 3 05-15-2006 02:53 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
