Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-23-2009, 07:40 PM   #1
Help with Murray/Noma snowblower
Hi,
I have a Murray/Noma snowblower. I have to replace one of the augers. It is a two stage blower. I can't figure out how to remove the old auger. I removed the screws supporting the auger on each side of the housing but the center gearbox is tied to the impeller and wonder if someone can give me an idea of how to remove the assembly. I thought either the auger assembly would have slid off the impeller shaft or the auger/impeller assembly would have slid out of the motor housing. The exploded parts view does not show any retaining rings anywhere. Do I have to disassemble the auger gearbox?
tomwa1vta is offline   Reply With Quote
arien snowblower jimb58 Tools 1 01-14-2009 07:56 PM
Toro snowblower adjustments Tom Fraser General Discussion 1 01-03-2009 07:04 PM
Toro snowblower tuna Ted General Discussion 2 01-01-2009 06:20 PM
jammed snowblower Dee_M General Discussion 11 11-28-2008 12:19 AM
Toro SnowBlower 521 metallic sound mteach General Discussion 1 12-13-2007 01:27 PM
