Help With Moisture Barrier - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 03:00 AM   #1
Help with moisture barrier
Ok so I have been working on framing out my basement walls. We just had a heavy rain here and this evening notices moisture spots on my basement wall. The wall is made of cinder blocks.
So I was wondering what would be the best way to treat this. Moisture barrier foam boards or barrier plastic that is stapled on framing studs.
Any help is appreciated.
Aloha1 is offline   Reply With Quote
Old 10-25-2011, 07:28 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
When I bought my house it had plastic up against the cement with 2X2 framing over it. There was a zoo of stuff growing behind the plastic. It stank. I removed it all and left it bare.
PoleCat is offline   Reply With Quote
Old 10-25-2011, 07:44 AM   #3
Rewards Points: 1,294
If water is seeping in from the outside then the problem needs to be addressed from the outside. Water getting into the block cannot be stopped with an interior vapor barrier. The waterproofing on the outside of the blockwork either was not applied properly or has been comprimised somehow. you do not want to trap water behind any type of wall you are putting up. Vapor barriers are to keep warm moist interior air from condensing in the cooler insulation in the walls.
danpik is offline   Reply With Quote
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
how important is it for moisture barrier to cover sides of floating floor? conradA Flooring 2 04-29-2010 11:13 AM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 12:51 PM
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 10:48 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
