HELP! Lighting Question For Vaulted Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-12-2008, 04:46 PM   #1
HELP! lighting question for vaulted ceiling
workshop studio 20x24 with centered ceiling fan.
My studio is going to have vaulted ceiling.It has 9ft walls and 10/12 pitch roof. I want fluorescent lighting because I can get high kelvin with wider coverage to paint by.
I could mount all four of the 4 ft. 2 bulb fluorescent as a hanging shop light 5 feet from the wall on all 4 sides of the studio. This way I have the complete center of the room and to the walls lighted. I would have all on one wall switch. I wanted to leave the pull string so I can have the ability to turn off each light should I need less than 4.
I am wondering now would the four hanging fluorescent shop lights ruin the look and feel of the vaulted ceiling? What is your suggestion on how to mount lights on a vaulting ceiling? Now that I am thinking about it, I could have nice fluorescent fixture mounted flat on the slant of the vaulted ceiling opposite of each other, then on the ends I could have the other lights hanging as a shop light with the on of pull string.
Any suggestions would be appreciated.
Maybe having cable supported utilitarian lighting would be a good choice. I am wondering about the heat and the energy it would take to burn these kinds of lights compared to fluorescents.
I wish I could find pictures, this would help a whole lot.
pauls is offline   Reply With Quote
Old 12-12-2008, 06:27 PM   #2
Rewards Points: 6,652
You have to hang them from either chains, steel rods, or cables from the ceiling. As for the type of lights, ever been in an Art Gallery or Furniture center that uses Spots?
Old 12-12-2008, 08:25 PM   #3
biggles's Avatar
go over to GOOGLE and put in "hanging florecents from vaulted celings" hit images....they show pix of one where they are mounted the same angle as the ceiling straight up,and you don't even see them...ever consider track lighting right along the wall where it meets the ceiling you can slide those on the tracks.4 seperate tracks with light switches in each corner of the studio to control tracks
Old 06-30-2010, 10:51 PM   #4
HICjim
Hi Paul,
Once the ceiling is up, recessed lighting is not only a "bear" to install in an insulated/vaulted situation, but fairly expensive as well.
I just did some work for a customer who used track lighting, and it looked AMAZING....... The guy who did the install used surface mould to bring power to the light bars, and did a very sweet looking job. It didn't have that "added-on" look either. I tip my hat to whoever did the work. I'm not easily impressed, but I was here.
The reason my customer chose the track lighting was simple...... She HATES working under fluorescent lights, because it makes her "feel" like she's at work!
HICjim is offline   Reply With Quote
Old 07-03-2010, 05:40 PM   #5
Rewards Points: 2,634
Not sure what look you are going after, but like Biggles suggested, if you do some searching ( I mean beyond isle 3 of the big box stores ) I expect you can find some flourecent fixtures that would look very nice hanging.
Myself, I don't think I would like the fixtures mounted to the sloped walls.
I have suspended monorail track around my vaulted ceiling. The look is what I was after, but I would have preferred more flourecent lighting.
SPS-1 is offline   Reply With Quote
Old 07-03-2010, 05:53 PM   #6
It seems the main drivers in this project are color temp and brightness.
Fluorescent people, like Lithonia, can tell you the uniformity of brightness for your specific layout by using their computer generated plots. Your odds of getting an answer are better if you have or make up a company name. I have two company names and only one has actual paying customers.
IMHO, the problem as stated is overconstrained. You'll have to give up on at least one of the design goals.
If no ceiling fan, then you could use a 20'x24', or smaller, diffuser which would probably exceed your unspoken cost constraint.
Office lighting calls for an intensity of ~500 lux.
http://en.wikipedia.org/wiki/Lux
lighting for low basement ceiling South Portlander Electrical 16 01-28-2012 07:25 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 10:47 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Question about ceiling joists... StlJoe Building & Construction 5 12-06-2005 12:52 PM
