Help! Installing Preformed Laminate Counters - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 08:14 PM   #1
Rewards Points: 150
help! installing preformed laminate counters
Hi! We are about to install preformed laminate counters to the base cabinets and was wondering if you are supposed to screw through the plastic corner piece on the base cabinet (it has a hole in it for screw) directly into the underside of the counter (which is just particle board). Of course, we will use the correct size screw so as not to come thru the top of the counter, but is this the correct way? Everything we can find on it says to screw to the underside of the counter, but I don't want to mess up my new counters if this not correct. We need help! Thanks in advance!
guest is offline   Reply With Quote
Old 02-19-2011, 01:37 AM   #2
Registered User
Rewards Points: 5,236
Yep, page 201; http://books.google.com/books?id=odQ...page&q&f=false Be mindful they are only plastic....
Don't forget to scribe the backsplash to the wall before installing countertop.......
Gary
Old 02-19-2011, 07:15 AM   #3
I sometimes add a dab(not a bead) of silicone adhesive at the cabinet corners, also. Usually not needed, but just to make sure. The screws do the holding.
Old 02-19-2011, 08:37 AM   #4
Rewards Points: 125
I'd second Bill's comment, a couple of screws to locate them and then silicone will hold them snugly. Once properly installed, countertops tend to be trapped against the walls and between appliances so they don't have much tendency to move very much. In my experience most of the movement tends to be backwards, from leaning against the tops, so as long as they are firmly set to the wall you should be fine.
And totally off-topic, hey Wilmington! Good to see another local DIYer on here, I'm trying to be handy in New Castle
ThatDaveGuy is offline   Reply With Quote
Old 02-19-2011, 10:09 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
The plastic corners are sometimes very flimsy so be careful not to wind the screw so hard that it could come up through the countertop.
tcleve4911 is offline   Reply With Quote
Old 02-19-2011, 02:07 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are the plastic corners screwed or stapled to the cabinets?
In some cases they are only stapled and probably should be checked for stability if you intend to use them to "draw-down" a counter top.
XXX
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
Installing pre-hung door over tile to laminate transition aldgagnon Carpentry 5 10-26-2010 06:37 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 08:38 AM
Installing Laminate in Kitchen/Ceramic Tile in Hallway ssutton3014 Flooring 1 10-18-2007 12:18 AM
