Help Hang Garden Tools In Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 08:14 PM   #1
It's always something
Rewards Points: 150
Help hang garden tools in garage
I need some ideas on how to create a garden-tool hanging system. I've been to the box stores and the systems they have are over-priced and most didn't have instructions on how to attach them to cinder blocks. That makes me want to stay away from them in fear they wouldn't hold very well.
As stated, my garage walls are plain cider blocks; no drywall, no studs. What can I do to create a rack that will hold my rakes, shovels, weed eater etc?
SingleGuy is offline   Reply With Quote
Old 03-31-2012, 08:57 PM   #2
Rewards Points: 13,270
The best, most versital and strongest one I've used is this one.
http://www.rubbermaid.com/Category/P...geOrganization
Peg board with the 1/4 holes over 2 X 2's to space it out away from the wall would also work and would give you hundreds of differant ways to hang just about anything.
Anyway you go it's pretty simple to just attach a board to the wall or even install it directly with Tap Con screws.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
SingleGuy (03-31-2012), user1007 (04-02-2012)
Old 03-31-2012, 09:00 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Unhappy
Attach a length of 2 by 4 with Tapcons. Drive 16 penny nails to meet you need. Been done for a 100+years.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
DexterII (04-01-2012), SingleGuy (03-31-2012)
Old 03-31-2012, 11:25 PM   #4
Rewards Points: 150
Thanks. The rubbermaid is too pricey. Those hangers are around 10 bucks each I'm going to try the TapCons. Now to figure how many TapCons for the given weight. I figure one every cinder block should be good. The heaviest items will be my weedeater and maddock. I'll probably just use several shorter 2x4s so the weight isn't too great on one long 2x4
Old 04-01-2012, 07:32 AM   #5
MarginallyQualified
Rewards Points: 2,464
Bassick makes the ONLY one worth having.
At Grainger this thing is # 6A111.
At about $4 each it's almost as cheap as a nail.
The Following User Says Thank You to TarheelTerp For This Useful Post:
SingleGuy (04-01-2012)
Old 04-01-2012, 10:31 AM   #6
Rewards Points: 52
RJ's got the right idea. There are a lot of what I suppose could be called "neat" things available commercially, but, especially for garden tools, it's hard to beat a length, or two, of 2x4 with nails. Maybe one high, for rakes, shovels, weed wackers, etc., and one half way down their handles, for smaller items like clippers, pruners, etc.
The Following User Says Thank You to DexterII For This Useful Post:
Old 04-01-2012, 11:35 PM   #7
Rewards Points: 150
Thanks everyone. Here's what i came up with this afternoon. I didn't take a 'before' shot but just imagine all the tools seen plus several more just propped up in the corner. I still have a few more tools to hang up but this gets the idea across very well I think. Total cost: $3.00. I already had the wood and screws. I just needed to buy the TapCons.
The overall project:
Weedeater and some accessories fit nicely together now
The weedeater sits nice and flush atop the 2x4 which has two nails to keep it from falling down. they're not seen which is even nicer
The tools are all supported by 2x4s which are screwed into the 2x4 that is mounted on the block:
The TapCons are easily the best thing I've ever worked with:
The Following User Says Thank You to SingleGuy For This Useful Post:
lynnbrwn (04-06-2012)
Old 04-02-2012, 06:54 AM   #8
Too Short? Cut it Again!
And nails can be useful. I used to pay around $4 for a box of real 16p or even 20p nails. A bit more to flow through nail guns.
Your project looks nice. Makes me wish I had a yard again. But then I live just off when one of the nicest parks in the country and somebody else seems to mow the turf on store the maintenance tools somewhere.
The Following User Says Thank You to user1007 For This Useful Post:
SingleGuy (04-02-2012)
Old 04-02-2012, 04:39 PM   #9
Thanks for sharing. That is a simple, inexpensive solution. I'm going to try it in my garage this weekend!
Curiousite is offline   Reply With Quote
The Following 2 Users Say Thank You to Curiousite For This Useful Post:
oh'mike (04-02-2012), SingleGuy (04-02-2012)
Old 04-04-2012, 02:28 PM   #10
biggles's Avatar
run 2 pieces of 2 X 4 along the cinder block ...wing nut it up then drill 3/8" holes thru all the handles nice and neat shovel brooms rakes.thn a smaller 2 X 4about 24" to hold the smaller items when your on your knees doing the beds...tip also drill a lenght of pine along the top of the 2 X 4s as a junk shelf.
The Following User Says Thank You to biggles For This Useful Post:
SingleGuy (04-04-2012)
Old 04-04-2012, 11:33 PM   #11
Too Old
?? I don't get it, pics please.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 04-06-2012, 04:48 PM   #12
Thanks for sharing. I was trying to find a solution for storing my tools and making shelves in my garage
lynnbrwn is offline   Reply With Quote
Wiring Garage Sconces paredown Electrical 1 03-28-2012 04:08 PM
MWBC to Garage Questions benleef Electrical 3 02-22-2012 12:02 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Feeder line from detatched garage to garden shed. abeeline Electrical 1 09-11-2010 06:25 PM
