Help - Had An Upstairs Toilet Overflow.. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-14-2009, 10:37 AM   #1
Lake Forest, CA
help - had an upstairs toilet overflow..
I could use some advice here.. an upstairs toilet overflowed and the water pooled up on the floor.. some has gone down into the subfloor and down along the walls.. I can see where it is draining out in the downstairs bathroom (which I am currently remodeling :-) ) and I can see where it has started dripping in the garage as it made its way in the subfloor.. I drilled drain holes to let it seep out however I am unsure what, if anything else I can do about it.. Will it dry naturally or am I in for a lot more work? We seem to have caught it in the early stages.. it could have been much worse..
SKINNY is offline   Reply With Quote
Old 03-14-2009, 10:53 AM   #2
Lake Forest, CA
the dripping and seeping has stopped so I am most concerned about the interior walls and subfloor drying..
Old 03-14-2009, 07:32 PM   #3
Drywall contractor
Rewards Points: 1,070
As long as they weren't saturated and didn't stay wet for a long period of time, they should dry out fine.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-14-2009, 10:11 PM   #4
Lake Forest, CA
Thanks.
Old 03-15-2009, 11:34 AM   #5
ccarlisle's Avatar
Well, we would first ask where the water came from? the toilet bowl or the toilet tank. One is clean water the other grey water and then act accordingly.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-15-2009, 12:19 PM   #6
Drywall contractor
I would assume it's the bowl and likely "gray water" (the tank doesn't normally "overflow"). Still, are you going to tear out the floor in the upstairs bath, drywall ceilings and walls in the downstairs bath , and garage ceiling?? Kind of costly for something that happens all too often. I WOULD have a lot more repair work if people DID tear out every time the commode overflowed.....
Old 03-15-2009, 02:48 PM   #7
Lake Forest, CA
It was the "gray water" from the bowl.. Somehow my daughter clogged the drain and at the same time the flapper got stuck open due to a chain coming loose and entering under the flapper.. The water seemed very clear so it wasn't like a sewage spill or anything (thank goodness).. The seeping stopped rather quickly and there didnt seem to be any real saturation of wallboard so I think I lucked out and caught it before it really caused a disaster.
Old 03-16-2009, 08:47 AM   #8
ccarlisle's Avatar
I don't assume anything in water damage restoration. Done it too long and I'm paid not to. Plus what starts out as clean water can become grey - even black - within days...these are categories of water - not the colour.
At the same time, a 'grey' water incident doesn't always require tearing out the floor, the walls or the ceiling below. But drying the affected areas is a permanent as well as perhaps treatment for any microorganisms that may be there. Now depending on how much water there was and the accessibility to it, you may need some tear-out to be on the safe side but that is case-dependent. Dry it out thoroughly with fans over 24hours, apply a disinfectant just in case and report back. You may see paint peeling after some time - not right away - and plaster may swell. But these are fixable.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet vent in upstairs sink line DavidT Plumbing 1 02-28-2009 07:29 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
