Help With Grease Gun 101 - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-23-2013, 05:54 PM   #1
Rewards Points: 274
help with grease gun 101
How can I tell if I am adding too much grease to fittings (don't want to blow any seals)?? Does grease start to spew out the sides of gun fitting as opposed to none leaking out and all going into fitting?
ugabulldog is offline   Reply With Quote
Old 07-23-2013, 06:24 PM   #2
Rewards Points: 12
What kind of fittings are you greasing?
Dan
djlandkpl is offline   Reply With Quote
Old 07-24-2013, 05:52 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
You should see the old grease being pushed out of the cavity by the new grease. If it comes out at the zerk it is not going into the bearing.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-24-2013, 03:05 PM   #4
Rewards Points: 274
Add appropriate proportion of grease not too much.
alexjoe is offline   Reply With Quote
Old 07-29-2013, 11:07 PM   #5
RealRobD's Avatar
First things first. Clean the zerk of any dirt or debris.
Pump your gun till grease starts to ooze out of the boot or joint. At this point you can stop or shoot a little more in there trying to displace some of the old grease. Wipe off any that oozes out and wipe the zerk clean so it doesn't attract more dirt than it should.
If the grease is not entering the zerk then it may need to be replaced or cleared with a special tool.
It never ceases to amaze me how many people never mention cleaning off the zerk fitting before and after lubrication
RealRobD is offline   Reply With Quote
Jenn Air grease trap av-geek Appliances 4 01-16-2013 07:59 PM
OTH microwave shooting grease into the air dankoos Appliances 12 01-13-2013 11:37 AM
Grease For Gas Valve and Where to Buy It AllanJ Appliances 6 12-01-2011 10:37 AM
Power tool grease Squishy Tools 2 11-29-2010 06:15 PM
Bearing grease Ultrarunner2017 Appliances 6 01-16-2009 07:41 AM
