Help With Glue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 09:29 AM   #1
Rewards Points: 31
Help with Glue
What is an appropriate glue to glue two small plastic pieces together. The AC adapter on my colleague's document camera broke. From past experience I've found that Super glue and it's ilk do not work well. Does Gorilla glue work well in this type of application? I am just worried about the stress it takes with the plug being pulled in and out all the time. The piece itself is soldered onto a board and cannot be easily replaced. Thanks for the help.
GRFagan is offline   Reply With Quote
Old 01-11-2012, 10:05 AM   #2
joed's Avatar
Rewards Points: 12,862
Every type of plastic takes a very specific glue suited only to that plastic. Many of them are not actually glue but a slovent that disloves the plastic and welds the two pieces together.
Old 01-11-2012, 10:23 AM   #3
Ironlight's Avatar
joed is spot on. It may take some trial and error to find the right product. In my experience super glue is great on some types of plastic and useless on other types, particularly parts with small surface area and stress on them.
I would actually start by trying a two-part epoxy formulated for plastic which seems to work on the broadest range of plastic. If this is a functional fix and not an aesthetic one, consider reinforcing the join between the broken parts with additional material if the join is going to be under any sort of stress.
Ironlight is offline   Reply With Quote
Old 01-11-2012, 11:38 AM   #4
Rewards Points: 31
Joed, can you suggest a type that might be appropriate?
Old 01-11-2012, 02:31 PM   #5
Hardcore DIY'er
My wife has a glue sold at hobby lobby (craft store) that is amazing, dont know the name but I would check a craft store. In my personal experience when it comes to plastic I always say epoxy, not glue. Glue soaks into pores and hardens, epoxy's are typically 2 part solutions. In fact I know Super Glue, the brand, makes one just for plastic. As for gorilla glue, my first lesson with gorilla glue was that it expands. I found that its great for 2 pieces that interlock loosely and you need to glue them together tight, not for pieces that the bond is broken and you want to repair it. Gorilla glue will expand and push the pieces apart before it hardens.
EvilNCarnate is offline   Reply With Quote
The Following User Says Thank You to EvilNCarnate For This Useful Post:
woodworkbykirk (01-12-2012)
Old 01-11-2012, 05:27 PM   #6
joed's Avatar
Hot glue. That stuff sticks to almost everything or Duct tape
Old 01-11-2012, 07:45 PM   #7
Rewards Points: 2,638
Whatever you use, first roughen up the surface with some sandpaper. It will give the adhesive something to "bite" into. I have had succcess with PL Premium adhesive caulking on plastic. That is a polyurethane adhesive, somewhat similar to Gorilla glue, but it has more mechanical stiffness, if you can put in on very thick.
SPS-1 is offline   Reply With Quote
Old 01-12-2012, 10:46 AM   #8
Too Short? Cut it Again!
SuperGlues were never really designed for plastics. Guerilla Glue and Guerilla Tape are gifts from God. Not really for plastics though.
Plastic store may help.
Just a silly suggestion though before you run off and spend a fortune on fixes? I wanted an extra AC adapter for a device of mine. Brand new, $5 including shipping, on eBay and delivered just last week. I don't think I could be any glue or figure out a fix with it for that kind of chimp change.
The converter tip systems sold at Radio Shack and other places may be an option also. Just switch the tips to charge near anything. Higher end systems allow for switching the voltage output also. One AC adapter (or cigarette lighter version). Just switch tips if you want to use it for other devices. I think they are like $20 to get started? The tips are not overly expensive.
When in doubt? X-Acto and duct tape to get you by. Everybody should own a glue gun though. I cannot see using it and the melted stuff to hold an AC convertor together for long without tape. Like I say, I fear you are approaching $30 in rescuing/repairing a device that may only cost you $5. And how did this thing fracture in the first place? Might not be rescuable and may soon be a repaired fire hazzard?
Old 01-13-2012, 06:40 PM   #9
Rewards Points: 1,062
What kind of plastic is it? There are so many. Polyethylene or polypropylene- no "glue" will really fuse them together. Epoxy (2 part) is best bet. Now, if the plastics are styrenes/vinyls/etc these can be fused/"glued" with good results. Without knowing, epoxy is best choice. Part of the reason lastics are so "indestructible' is the fact that they inherently do not react with nature, also glues.....
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-14-2012, 05:13 AM   #10
I am sorry but this thread is insane. You do not glue together a power adapter. It is irrelevant what plastic is involved. Go to eBay and get a new one.
Old 01-14-2012, 09:08 AM   #11
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
sdsester, why do you spell Gorilla glue as "Guerilla"?
I am just curious if you meant to or was it some kind of Freudian slip?
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
user1007 (01-14-2012)
Old 01-14-2012, 11:31 AM   #12
Andy.
Freud never really slipped. I do therapy every Wednesday. Most people scatter knowing I am nearing. Entire blocks of Chicago for my 45 minute session clear when I sit down with my guy. To talk about stuff. Andy, are you sure you want to mess with me or be added to my list? Are you the guy I should talk about next.
Tell me Andy, how would you propose the spell Argangtain?
Old 01-14-2012, 11:41 AM   #13
AndyGump's Avatar
Rewards Points: 684
Ah, I see now that it was not so much a Freudian slip as it was a Jungian Blouse.
Ha ha.
I feel safe in the knowledge that you are in Chicago and I am in California.
Andy.
Old 01-14-2012, 11:52 AM   #14
Ha ha.
Andy.
Lived in Northern for California for near three decades. Raced sailboats around the SF Bay and up and down the California and extended West Coast. Once did the insane race all the way to Hawaii. Took us two days as I remember.
No responsible Californian fails to realize it is just a matter of time before, and I hope near within minutes Florida, both fall into the depths. Nothing much missed in either case. As your kids climb for shore, in Nevada. You are going to be begging for safe Lake Michigan area property.
And it snows here, try splaining that to your Orange County kids,
Old 01-14-2012, 11:56 AM   #15
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by sdsester
Lived in Northern for California for near three decades. Raced sailboats around the SF Bay and up and down the California Coast. Once did the insane race all the way to Hawaii. Took us two days as I remember.
So did I.
(except it was an off-shore cigarette with twin blown 572's)
But things have changed a lot in a short time over there.
titanoman is offline   Reply With Quote
To Glue or Not To Glue denvermatt Carpentry 9 08-22-2011 09:21 PM
carpet glue pfmartin0387 Flooring 1 10-03-2010 08:17 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 10:12 PM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 02:16 AM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 11:56 AM
